Page History: Delta 40-440 scroll saw spring replacements
Page Revision: 2018/08/22 07:31
For those of you restoring a Delta 40-440 scroll saw with missing springs as I have recently done there are contemporary equivalents available.
The following springs are available at Century Spring Corp. Please refer to the following Vintage Machinery document for item numbers indicated below: http://vintagemachinery.org/pubs/detail.aspx?id=1529
The table's trunnion locking knob's spring: Delta part #NCS-33 (item #90) can be replaced with: http://www.centuryspring.com/compression-spring-3253.html
The stop rod spring: Delta part #NCS-179 (item #25) can be replaced with: http://www.centuryspring.com/compression-spring-h-88.html
The air pump springs: Delta part #NSS-219 (item #109) can be replaced with: http://www.centuryspring.com/compression-spring-ii-86.html
