Page Revision: 2018/04/21 18:12
Examples of Drum Condition
By Bob Vaughan
Outside ends of worn drums
Belt sander drum details:
Inside of worn drums:
The images below are examples of improper crowns caused by wear, in this case shown on a Powermatic 6x48 sander.
Worn drum on 6x48 sander
The crown needs to be corrected for proper tracking.
Additional images of the usual W-shaped drums
Delta 6x48 31-730 sander repair details(16 pictures):
Re-Crowning Drums
Turning on a Lathe
By Bob Vaughan
PM 30 sander belt tracking blues
I'll put the shaft in the lathe, then put on both drums with needed spacers, then turn both drums at the same time using the compound over at some slight angle like 1º or so per side, giving a slight V crown rather than a round one. The angle will likely dictated by the thickness of the drum. When I re-crown, its a matter of reacting to the geometry of whatever's in front of me. The big thing is to get rid of that upturn profile on the outer edges. Its those outer edge diameters that makes tracking impossible under load.
Below is an idler drum restored on the lathe.
By Shane Whitlock
Rockwell Belt Sander Restoration Pics (updated all finished)
You can see here the drive drum is a little wallowed...
Tracking is great now.
By Bob Vaughan
Powermatic 30 sander restoration, belt won't track straight
Redneck machine shop job:
  • Rip a 1/2" wide strip of belt.
  • Install on machine.
  • Turn on machine and get belt tracking one side or the other to drive the top drum.
  • Crown the wheels by hand, first one side, then the other.
Forming a Crown With Tape
