Page Revision: 2008/03/29 22:58
A Brief History of Delta Cast Iron Stands
(from a post on OWWM.org by Keith Bohn 09/24/06) http://www.owwm.org/viewtopic.php?t=20014
Delta No. 667 Cast Iron Stand: The first cast iron base (not counting grinders and multi-spindle drill press set-ups) was for the No. 654 Delta 6” Jointer (NJ casting numbers). It appeared in the 1939 catalogs as the No. 667 Cast Iron Stand. Combined with the No. 654 jointer it was sold as the No. 666 6” Jointer. The cast iron stand was offered as an option to the No. 656 Steel Stand.
  • NJ-273 Front Base Panel
  • NJ-276 Left Hand Base Panel
  • NJ-277 Motor Plate
  • NJ-287 Pulley Guard
  • NJ-288 Rear Base Panel
Delta No. 886 Cast Iron Stand: The next cast iron stand to be offered by Delta was the No. 886 for the No. 890 14” Wood Cutting Band Saw and the No. 880 14” Metal Cutting Band Saw. It first appeared in the 1941 catalog. It was offered as an option to the No. 891 Open Steel Stand.
  • LBS-225 Front Base Panel
  • LBS-226 Rear Base Panel
No. 31-852 Abrasive Finishing Machine Stand: This stand first appeared in the 1940 catalog and was an adaptation of the existing No. 667 6” Jointer Stand with the addition of parts making it specific for use under the No. 1400 6” X 48” Belt Finisher. It was offered as an option to the No. 1406 Open Steel Stand.
  • BS-263 Sub-Base
  • BS-264 Pulley Guard
No. 886 Cast Iron Stand: Like the No. 31-852 stand the pre-existing No. 886 stand was adapted for use under the No. 1160 10” Tilting Table Saw. It first appeared in the 1943 catalog was offered in addition to the No. 891 Open Steel Stand.
No. 37-302 Cast Iron Stand: The last machine to be fitted with a cast iron stand was the No. 37-301 Delta (Crescent) 8” Jointer. This jointer was made available without the stand but no open stand was ever offered.
  • JA-1 Base Front Panel
  • JA-2 Base Back Panel
  • JA-3 Motor Cover
  • JA-29 Motor Mounting Plate
  • JA-32 Pulley Guard
  • JA-49 Name Plate
