Page Revision: 2008/03/29 23:02
A Brief History of Delta Cast Iron Stands(from a post on OWWM.org by Keith Bohn 09/24/06)
http://www.owwm.org/viewtopic.php?t=20014Before we begin this little romp down memory lane there are two significant details that need to be known that are significant to the cast iron stands.
Delta No. 667 Cast Iron Stand:
- NJ-273 Front Base Panel
- NJ-275 Right Hand Base Panel
- NJ-276 Left Hand Base Panel
- NJ-277 Motor Plate
- NJ-283 5/16-18 Knurled Nuts (8-req’d.)
- NJ-287 Pulley Guard
- NJ-288 Rear Base Panel
- Cat. No. 132 Switch Box With SP-2458 Switch (purchased separately)
- DP-741 Front Name Plate (Vertical DELTA Plate)
- LSR-35 Delta Switch Plate Cover (domestic machines)
- LSR-36 TAUCO Switch Plate Cover (export machines)
Delta No. 886 Cast Iron Stand:
- LBS-225 Front Base Panel
- LBS-226 Rear Base Panel
- LBS-227 Left Hand Base Panel
- LBS-228 Right Hand Base Panel
- LBS-229 Motor Mounting Plate
- LBS-194 Cover Casting for Cat. No. 883 Cast Iron Hinged Belt Guard
- NJ-283 5/16-18 Knurled Nuts (4-req’d.)
- BS-263 Sub-Base
- BS-264 Pulley Guard
- TCS-316A & TCS-317A (Cat. No. 1173) Belt Guard
No. 37-302 Cast Iron Stand:
- JA-1 Base Front Panel
- JA-2 Base Back Panel
- JA-3 Motor Cover
- JA-29 Motor Mounting Plate
- JA-32 Pulley Guard
- JA-49 Name Plate
