Page Revision: 2008/04/02 16:36
(from a post on OWWM.org by by Keith Bohn 09/24/06) http://www.owwm.org/viewtopic.php?t=20014
A Brief History of Delta Cast Iron Stands
Delta No. 667 Cast Iron Stand
  • NJ-273 Front Base Panel
  • NJ-276 Left Hand Base Panel
  • NJ-277 Motor Plate
  • NJ-287 Pulley Guard
  • NJ-288 Rear Base Panel
Delta No. 886 Cast Iron Stand
  • LBS-225 Front Base Panel
  • LBS-226 Rear Base Panel
  • BS-263 Sub-Base
  • BS-264 Pulley Guard
No. 37-302 Cast Iron Stand
  • JA-1 Base Front Panel
  • JA-2 Base Back Panel
  • JA-3 Motor Cover
  • JA-29 Motor Mounting Plate
  • JA-32 Pulley Guard
  • JA-49 Name Plate
