Page Revision: 2012/03/04 18:00
(from a post on OWWM.org by by Keith Bohn 09/24/06) http://www.owwm.org/viewtopic.php?t=20014
Delta No. 667 Cast Iron Stand
  • NJ-273 Front Base Panel
  • NJ-276 Left Hand Base Panel
  • NJ-277 Motor Plate
  • NJ-287 Pulley Guard
  • NJ-288 Rear Base Panel
Delta No. 886 Cast Iron Stand
  • LBS-225 Front Base Panel
  • LBS-226 Rear Base Panel
No. 31-852 Cast Iron Stand
  • BS-263 Sub-Base
  • BS-264 Pulley Guard
No. 886 Stand for Tablesaw
No. 37-302 Cast Iron Stand
No. 37-302 Jointer Stand
  • JA-1 Base Front Panel
  • JA-2 Base Back Panel
  • JA-3 Motor Cover
  • JA-29 Motor Mounting Plate
  • JA-32 Pulley Guard
  • JA-49 Name Plate
Example Photos
No. 31-852 on left, No. 886 on right - image courtesy of Jeff Parker (JParker)
No. 31-852 on left, No. 886 on right - Image courtesy of Jeff Parker (JParker)
