Page Revision: 2008/03/31 15:14
by Keith Bohne-mail: UnisawA100@wi.rr.com
after 1941. This makes it difficult if you have a machine dating prior to that. The serial number tags basically came in two flavors.
The earlier tags measured approximately 1/2' X 3' with rivet holes approximately 2 3/4' on center. To the best of my knowledge these were only used during the
late 30's to the early 40's.
Older Delta Serial Number Tag |
I mention the rivet holes because some machines, for whatever reason, may have had their serial number tags stripped from them making a positive vintage
harder. You can however locate these holes and a ghost image of the tag and narrow down the machine's vintage. Where tags were located on individual
machines would take a paper unto itself. I should also note, tag locations on the same machines weren't always located in the same spot. For instance, I've
seen tags on the back of a Unisaw cabinet as well as the front.
It's not been substantiated fully but all evidence points to a fact that Delta did not tag machines from 1941 to 1943. Whatever the reason I'm not sure. If you
have a machine from this era and it has a confirmed serial number I would like to hear from you. Please read the rest of this article though before positively
determining your machine's vintage. It's also come to light, from various discussions on the OWWM discussion forum, that Delta used some serial numbers
during the same period that don't quite jive with what's known by me. For instance, some five digit serial numbers on 1' by 4' tags don't compute with my
list or Delta's. If ever this mystery is solved this write up will be amended.
About This Serial Number List:I received this list from a fellow OWWM member. Someone had given it to him at his local Delta service center with no explanation or additional information.
The following is based on
Year | From | - | To |
The Bellefountaine Years:
1951 | AA-100 | - | AB-7478 |
1956 | BM-100 | - | BO-9822 |
1962 | CU-4300 | - | CK-9999 |
1969 | EG-100 | - | EI-208 |
1970 | EI-209 | - | EP-5295 |
1971 | EP-5400 | - | EW-236 |
1972 | EW-237 | - | FI-311 |
1973 | FI-312 | - | GA-782 |
1974 | GA-783 | - | GZ-2477 |
1978 | JX-100 | - | KP-9725 |
1978 | LW-103 | - | LW-9999 |
1979 | LV-100 | - | LV-9999 |
1979 | LX-100 | - | LX-9999 |
1979 | LY-100 | - | MB-5699 |
1982 | LO-100 | - | LO-9999 |
