Page Revision: 2017/03/13 16:57
by Keith Bohn
after 1941. This makes it difficult if you have a machine dating prior to that. The serial number plates basically came in four flavors.
The second style was a rare and short-lived brass plate that was used in late 1941 or early '42.
Delta Brass Wartime Plate |
The third style plates were made of "oilboard" (dense coated cardboard) and measured 3/4" x 3" with rivet holes spaced the same as the first style plates. They were used between early 1942 to sometime in 1944.
The fourth style began in late 1947. They are made of aluminum and measure 1" x 4" with rivet holes approximately 3-3/4" on center.
Some machines, for whatever reason, may have had their serial number plates removed or torn off, making a positive vintage identification more difficult. You can however locate the rivet or screw holes in the machine and perhaps a ghost image of the plate, and use the distance between the holes to narrow down the machine's vintage. Where plates were located on individual machines would take a paper unto itself. I should also note, plate locations on the same machines weren't always located in the same spot. For instance, I've seen plates on the back of a Unisaw cabinet as well as the front.
The following is based on
The strange jump from 15-0000 to 16-0000 is in the original. If your serial number lies between these two values then all we can say is that your saw dates from 1941 or '42.
Year | From | - | To |
The Bellefountaine Years:
Year | From | | To |
1951 | AA-100 | - | AB-7478 |
1956 | BM-100 | - | BO-9822 |
1962 | CU-4300 | - | CX-9999 |
1969 | EG-100 | - | EI-208 |
1970 | EI-209 | - | EP-5295 |
1971 | EP-5400 | - | EW-236 |
1972 | EW-237 | - | FI-311 |
1973 | FI-312 | - | GA-782 |
1974 | GA-783 | - | GZ-2477 |
1978 | JX-100 | - | KP-9725 |
1978 | LW-103 | - | LW-9999 |
1979 | LV-100 | - | LV-9999 |
1979 | LX-100 | - | LX-9999 |
1979 | LY-100 | - | MB-5699 |
1982 | LO-100 | - | LO-9999 |
Example: 83B01234
A = October | G = April |
B = November | H = May |
C = December | I = June |
D = January | J = July |
E = February | K = August |
F = March | L = September |
original document.
Decals and Plates: ¶
Milwaukee/Pittsburgh:
Stands and Motors: ¶
Part Numbers:
Got A Receipt?:
