Page Revision: 2010/01/30 16:52
by Keith Bohn
The first style plates were made of aluminum and measured 1/2" X 3" with rivet holes approximately 2 3/4" on center. This style was used beginning sometime in 1939/40 through 1941 and again from 1944 through 1947.
The second style were made of "oilboard" (dense coated cardboard) and measured 3/4" x 3" with rivet holes spaced the same as the first style plates.
Presumably, the oilboard style was used during a portion of WWII to conserve aluminum. Not being as durable as aluminum, they are often missing or in poor condtion.
The third style began in 1947. They are made of aluminum and measure 1" x 4" with rivet holes approximately 3-3/4" on center.
I mention the rivet holes because some machines, for whatever reason, may have had their serial number plates stripped from them making a positive vintage
harder. You can however locate these holes and a ghost image of the plate and narrow down the machine's vintage. Where plates were located on individual
machines would take a paper unto itself. I should also note, plate locations on the same machines weren't always located in the same spot. For instance, I've
seen plates on the back of a Unisaw cabinet as well as the front.
The following is based on
Year | From | - | To |
The Bellefountaine Years:
Year | From | | To |
1951 | AA-100 | - | AB-7478 |
1956 | BM-100 | - | BO-9822 |
1962 | CU-4300 | - | CK-9999 |
1969 | EG-100 | - | EI-208 |
1970 | EI-209 | - | EP-5295 |
1971 | EP-5400 | - | EW-236 |
1972 | EW-237 | - | FI-311 |
1973 | FI-312 | - | GA-782 |
1974 | GA-783 | - | GZ-2477 |
1978 | JX-100 | - | KP-9725 |
1978 | LW-103 | - | LW-9999 |
1979 | LV-100 | - | LV-9999 |
1979 | LX-100 | - | LX-9999 |
1979 | LY-100 | - | MB-5699 |
1982 | LO-100 | - | LO-9999 |
Example: 83B01234
A = October | G = April |
B = November | H = May |
C = December | I = June |
D = January | J = July |
E = February | K = August |
F = March | L = September |
original document.
Decals and Plates: ¶
Milwaukee/Pittsburgh:
Stands and Motors: ¶
Part Numbers:
Got A Receipt?:
