Page Revision: 2008/03/30 01:01
November 21, 2006
Early Band Saws in the OWWM Archives: A Research Paper in Eight PartsPart 1.
Patent dates and four footed cast iron, cast iron wheeled band saws
Eight are represented by archival photographic entries in various degrees of completeness. The D. C. Allen saw does not have a photographic entry. Of the eight with photographic entries all are of cast iron frame construction. Two of these have rounded cored ‘necks’ and necks separate from-and bolted on the-bed sections. These are the Welch, Harrison and the Welch & Chipman. Welch & Chipman saw
Welch, Harrison & Co. saw
The Rogers saw has a rounded cored neck cast integrally with the bed section. C. B. Rogers & Co. saw
Of the other five four are Pryibil related, two being First & Pryibil and the other two being Pryibil. All these four have rectangular sectioned cored necks cast in one piece, integrally, with the beds. First & Pryibil 1 First & Pryibil 2 P. Pryibil 1 P. Pryibil 2
The last example is the Collins & Greenwood saw which has a rectangular flanged bed. Collins & Greenwood saw
Patent dates are recorded as being cast into six of these eight saws. Neither the Collins and Greenwood saw or the Rogers saw has a record of a patent. Indeed, the C.B. Rogers company—active from around 1841 to 1897
held no patents on band saws. The Collins and Greenwood firm did patent, on August 12, 1873, a design for band saw frame.
Both the Welch, Harrison and the Welch & Chipman saws have the patent date of June 16, 1868 cast into them, and, therefore both saws were manufactured after that date. The four Pryibil related saws have several patent dates attached or cast onto them, as follows
* First & Pryibil Steere example
Aug 28, 1866 & Jan 7 1873
* First & Pryibil 'Woodshave' example
said to be 1876
* Pryibil Poore example
'Pat Aug 28, 1866 & Jan 7 1873'
* Pryibil Barnhart example
'Pat 1866 & 73'
* Welch, Harrison
after June 16, 1868
* Welch & Chipman
after June 16, 1868
after January, 1873
after January, 1873
after January, 1873
* Collins & Greenwood
after August 12, 1873
* D.C. Allen
after May 26, 1874
after 1876
* D. C. Allen
Concord NH
Lebanon NH
* C.B. Rogers & Co.
Norwich CT
* Welch & Chipmam
South Boston MA
* Welch, Harrison & C.
South Boston MA
* D. C. Allen
Concord NH
Lebanon NH
* First & Pryibil (2 examples)
New York NY
* Pryibil (2 examples)
New York NY
* C.B. Rogers & Co.
Norwich CT
* Welch & Chipman
South Boston MA
South Boston MA
Since four of the examples of this type of band saw are associated with the Pryibil firms in New York City and two others with the Welch firms in South Boston, only two enterprises—in the two largest cities of the sampleaccount for two-thirds of the archived band saws of this type.
Part 2.
Patent Dates and other early band saws that are non four footed, but are cast iron and do not have fully cast iron wheels
* Atlantic Works (5 examples)
* J.A. Fay & Co. (3 examples)
* Goodell & Waters (2 examples)
* L. Power & Co. (2 examples)
* Baxter D. Whitney (1 example)
* Atlantic Works
Hanson example last date 1873
* Atlantic Works
Potts example L.B & O last date 1871
* Atlantic Works
Streff example no record of patent mark
* Atlantic Works
Potts no. 2 example B & O no record of patent mark
* Atlantic Works
Gee example L.B. & O last date 1871
* J.A. Fay & Co.
Buck example last date 1874
* J.A. Fay & Co.
Haire example last date 1874
* J.A. Fay & Co. example? last date 1874
* Goodell & Waters
Thomas example no record of patent mark
* Goodell & Waters
Fisher example said to be 1882
* L. Power & Co.
Bernstein example no record of patent mark
* L. Power & Co.
Potts example no record of patent mark
* Atlantic Works
* Atlantic Works
* Atlantic Works
* J.A. Fay & Co.
* J.A. Fay & Co.
* Goodell & Waters
* J.A. Fay & Co. (as Page & Co.) 1834 (as J.A. Fay & Co.) prior to 1850
* Baxter D. Whitney (circa 1837)
* L. Power & Co. (circa 1867)
* Goodell & Waters (as Goodell, Braun & Co.) prior to 1869 (as Goodell & Waters) circa 1873 or 1874
* Atlantic Works (as Richards, Kelley, & Co.) 1870
Part 3.
Comparison of earliest
i.e. not latest patent dates of early band saws
* J.A. Fay & Co.
Haire example Reissued Aug. 25. 1865, Pat June 16.1868, Sept. 1. Nov. 1. 1871, May 21. 1872, May 19. 1874.
* First & Pryibil
'Woodshave' example said to be 1876
prob '1866 * Pryibil
Poore example 'Pat Aug 28 1866 & Jan 73'
* Pryibil
Barnhart example 'Pat 1866 & 73'
* Welch, Harrison
June 16, 1868
* Welch & Chipman
June 16, 1868
* J.A. Fay & Co.
Buck example June 16, 1868, Sept 19, 1871, Nov. 14, 1871, May 21, 1872, May 19,1874
* First & Pryibil
Steere example Aug 28, 1868 & Jan 1873
* Atlantic Works
Potts example L.B & O June 7, 1870, Jun. 28, 1870, Apr. 25, 1871, May 9, 1871
* Atlantic Works
Gee example L.B. & O June 7, 1870, June 28 1870, April 25, 1871, May 9, 1871
* Atlantic Works
Hanson example June 7, 1870, June 28 1870, April 25, 1871, May 9, 1871
May 19, 1874
only date recorded may be others? * Goodell & Waters
* Reissued Aug. 25. 1865
* Pat June16, 1868,
* Sept. 1 Nov. 1 1871,
* May 21, 1872,
* May 19, 1874.
Reissued Aug. 25. 1865 no J.A. Fay & Co patent this date
Pat June16, 1868, Improvement in guides for bandsaws
Sept. 1 Nov. 1 1871, no J.A. Fay & Co patent these dates
May 21, 1872, Improvement in pulleys for bandsaws
May 19, 1874. Improvement in band sawing machines
Part 4.
Jun. 16, 1868 J.A. Fay John Lemman
|Jun. 28, 1870 Atlantic Works William H. Thorne
1837 Baxter D. Whitney
1847 J.A. Fay
1867 L. Power
c. 1869 Goodell & Waters
c. 1869 Atlantic Works
