Page Revision: 2008/03/30 01:16
November 21, 2006
Early Band Saws in the OWWM Archives: A Research Paper in Eight Parts
Part 1.
Patent dates and four footed cast iron, cast iron wheeled band saws
Welch & Chipman saw
Welch, Harrison & Co. saw
C.B. Rogers & Co saw
Both the Welch, Harrison and the Welch & Chipman saws have the patent date of June 16, 1868 cast into them, and, therefore both saws were manufactured after that date. The four Pryibil related saws have several patent dates attached or cast onto them, as follows
* First & Pryibil Steere example
Aug 28, 1866 & Jan 7 1873
* First & Pryibil 'Woodshave' example
said to be 1876
* Pryibil Poore example
'Pat Aug 28, 1866 & Jan 7 1873'
* Pryibil Barnhart example
'Pat 1866 & 73'
* Welch, Harrison
after June 16, 1868
* Welch & Chipman
after June 16, 1868
after January, 1873
after January, 1873
after January, 1873
* Collins & Greenwood
after August 12, 1873
* D.C. Allen
after May 26, 1874
after 1876
* D. C. Allen
Concord NH
Lebanon NH
* C.B. Rogers & Co.
Norwich CT
* Welch & Chipmam
South Boston MA
* Welch, Harrison & C.
South Boston MA
* D. C. Allen
Concord NH
Lebanon NH
* First & Pryibil (2 examples)
New York NY
* Pryibil (2 examples)
New York NY
* C.B. Rogers & Co.
Norwich CT
* Welch & Chipman
South Boston MA
South Boston MA
Since four of the examples of this type of band saw are associated with the Pryibil firms in New York City and two others with the Welch firms in South Boston, only two enterprises—in the two largest cities of the sampleaccount for two-thirds of the archived band saws of this type.
Part 2.
Patent Dates and other early band saws that are non four footed, but are cast iron and do not have fully cast iron wheels
* Atlantic Works (5 examples) * J.A. Fay & Co. (3 examples) * Goodell & Waters (2 examples) * L. Power & Co. (2 examples) * Baxter D. Whitney (1 example)
* Atlantic Works Hanson example last date 1873 * Atlantic Works Potts example L.B & O last date 1871 * Atlantic Works Streff example no record of patent mark * Atlantic Works Potts no. 2 example B & O no record of patent mark * Atlantic Works Gee example L.B. & O last date 1871 * J.A. Fay & Co. Buck example last date 1874 * J.A. Fay & Co. Haire example last date 1874 * J.A. Fay & Co. example? last date 1874 * Goodell & Waters Thomas example no record of patent mark * Goodell & Waters Fisher example said to be 1882 * L. Power & Co. Bernstein example no record of patent mark * L. Power & Co. Potts example no record of patent mark * Baxter D. Whitney no record of patent mark
* Atlantic Works Potts example L.B & O last date 1871 * Atlantic Works Gee example L.B. & O last date 1871 * Atlantic Works Hanson example last date 1873 * J.A. Fay & Co. Buck example last date 1874 * J.A. Fay & Co. Haire example last date 1874 * J.A. Fay & Co. example? last date 1874 * Goodell & Waters Fisher example said to be 1882
* J.A. Fay & Co. (as Page & Co.) 1834 (as J.A. Fay & Co.) prior to 1850 * Baxter D. Whitney (circa 1837) * L. Power & Co. (circa 1867) * Goodell & Waters (as Goodell, Braun & Co.) prior to 1869 (as Goodell & Waters) circa 1873 or 1874 * Atlantic Works (as Richards, Kelley, & Co.) 1870
Part 3.
Comparison of earliest i.e. not latest patent dates of early band saws
Reissued Aug. 25. 1865, Pat June 16.1868, Sept. 1. Nov. 1. 1871, May 21. 1872, May 19. 1874.
said to be 1876 prob '1866
'Pat Aug 28 1866 & Jan 73'
'Pat 1866 & 73'
* Welch, Harrison
June 16, 1868
* Welch & Chipman
June 16, 1868
June 16, 1868, Sept 19, 1871, Nov. 14, 1871, May 21, 1872, May 19,1874
Aug 28, 1868 & Jan 1873
June 7, 1870, Jun. 28, 1870, Apr. 25, 1871, May 9, 1871
June 7, 1870, June 28 1870, April 25, 1871, May 9, 1871
May 19, 1874 only date recorded may be others?
said to be 1882
This list shows one J.A. Fay & Co. saw (the Haire example) as having both the earliest patent date claim and one of the latest. If this one instance is for the moment discounted—leaving twelve saws—the chronological division of the saws also shows georgraphical division, as the first seven saws are then those from New England and New York and the next six chronologically are those from Philadelphia and Cincinnati. Also, this chronological division shows type division—if the J.A. Fay & Co. saw (the Haire example) listed first is again discounted—as the first five examples (and six of the first seven examples) are of the four footed cast iron, cast iron wheeled—these are all of that type in this list, at the head of this list
and the last five are all of the non-four footed type.
* Reissued Aug. 25. 1865 * Pat June16, 1868, * Sept. 1 Nov. 1 1871, * May 21, 1872, * May 19, 1874.
Reissued Aug. 25. 1865 no J.A. Fay & Co patent this date Pat June16, 1868, Improvement in guides for bandsaws Sept. 1 Nov. 1 1871, no J.A. Fay & Co patent these dates May 21, 1872, Improvement in pulleys for bandsaws May 19, 1874. Improvement in band sawing machines
Part 4.
Jun. 16, 1868 J.A. Fay John Lemman Jun. 7, 1870 Atlantic Works John Richards |Jun. 28, 1870 Atlantic Works William H. Thorne Apr. 25, 1871 Atlantic Works John Richards Sep. 19, 1871 J.A. Fay William H. Doane Nov. 14, 1871 J.A. Fay William P. McKee? May. 7, 1872 Baxter D. Whitney Baxter D. Whitney May. 14, 1872 Baxter D. Whitney Baxter D. Whitney May. 21, 1872 J.A. Fay William H. Doane Apr. 8, 1873 Baxter D. Whitney Baxter D. Whitney May. 19, 1874 J.A. Fay William P. McKee? Jul. 13, 1875 Baxter D. Whitney Baxter D. Whitney Aug. 14, 1877 J.A. Fay George W. Bugbee Mar. 19, 1878 J.A. Fay Francis Clark Sep. 4, 1883 Goodell & Waters William G. Vernon Aug. 26, 1884 Goodell & Waters Louis T. Pyott Sep. 1, 1885 L. Power Louis T. Pyott
1837 Baxter D. Whitney 1847 J.A. Fay 1867 L. Power c. 1869 Goodell & Waters c. 1869 Atlantic Works
