Page Revision: 2008/03/30 01:44
November 21, 2006
Early Band Saws in the OWWM Archives: A Research Paper in Eight Parts
Part 1. Patent dates and four footed cast iron, cast iron wheeled band saws
Welch & Chipman saw
Welch, Harrison & Co. saw
C.B. Rogers & Co saw
Both the Welch, Harrison and the Welch & Chipman saws have the patent date of June 16, 1868 cast into them, and, therefore both saws were manufactured after that date. The four Pryibil related saws have several patent dates attached or cast onto them, as follows
August 28, 1866 & Jan 7, 1873
said to be 1876
'Pat 1866 & '73
The D. C. Allen saw, though not illustrated, is described as having a patent date of May 26, 1874May 26, 1874. Therefore this saw could not have been manufactured prior to that time.
  • Welch, Harrison
after June 16, 1868
  • Welch & Chipman
after June 16, 1868
after January, 1873
after January, 1873
after January, 1873
  • Collins & Greenwood
after August 12, 1873
  • D.C. Allen
after May 26, 1874
after 1876
  • D. C. Allen
Concord NH
Lebanon NH
  • C.B. Rogers & Co.
Norwich CT
  • Welch & Chipmam
South Boston MA
  • Welch, Harrison & C.
South Boston MA
  • D. C. Allen
Concord NH
Lebanon NH
  • First & Pryibil (2 examples)
New York NY
  • Pryibil (2 examples)
New York NY
  • C.B. Rogers & Co.
Norwich CT
  • Welch & Chipman
South Boston MA
South Boston MA
Part 2. Patent Dates and other early band saws that are non four footed, but are cast iron and do not have fully cast iron wheels
  • Atlantic Works (5 examples)
  • J.A. Fay & Co. (3 examples)
  • Goodell & Waters (2 examples)
  • L. Power & Co. (2 examples)
  • Baxter D. Whitney (1 example)
  • J.A. Fay & Co. (as Page & Co.) 1834 (as J.A. Fay & Co.) prior to 1850
  • Baxter D. Whitney (circa 1837)
  • L. Power & Co. (circa 1867)
  • Goodell & Waters (as Goodell, Braun & Co.) prior to 1869 (as Goodell & Waters) circa 1873 or 1874
  • Atlantic Works (as Richards, Kelley, & Co.) 1870
Part 3. Comparison of earliest i.e. not latest patent dates of early band saws
* J.A. Fay & Co. Haire example
Reissued Aug. 25. 1865, Pat June 16.1868, Sept. 1. Nov. 1. 1871, May 21. 1872, May 19. 1874.
* First & Pryibil 'Woodshave' example
said to be 1876 prob '1866
* Pryibil Poore example
'Pat Aug 28 1866 & Jan 73'
* Pryibil Barnhart example
'Pat 1866 & 73'
* Welch, Harrison
June 16, 1868
* Welch & Chipman
June 16, 1868
* J.A. Fay & Co. Buck example
June 16, 1868, Sept 19, 1871, Nov. 14, 1871, May 21, 1872, May 19,1874
* First & Pryibil Steere example
Aug 28, 1868 & Jan 1873
* Atlantic Works Potts example L.B & O
June 7, 1870, Jun. 28, 1870, Apr. 25, 1871, May 9, 1871
* Atlantic Works Gee example L.B. & O
June 7, 1870, June 28 1870, April 25, 1871, May 9, 1871
* Atlantic Works Hanson example
* J.A. Fay & Co. example?
May 19, 1874 only date recorded may be others?
* Goodell & Waters Fisher example
said to be 1882
* Reissued Aug. 25. 1865 * Pat June16, 1868, * Sept. 1 Nov. 1 1871, * May 21, 1872, * May 19, 1874.
Reissued Aug. 25. 1865 no J.A. Fay & Co patent this date Pat June16, 1868, Improvement in guides for bandsaws Sept. 1 Nov. 1 1871, no J.A. Fay & Co patent these dates May 21, 1872, Improvement in pulleys for bandsaws May 19, 1874. Improvement in band sawing machines
Part 4.
Jun. 16, 1868 J.A. Fay John Lemman Jun. 7, 1870 Atlantic Works John Richards |Jun. 28, 1870 Atlantic Works William H. Thorne Apr. 25, 1871 Atlantic Works John Richards Sep. 19, 1871 J.A. Fay William H. Doane Nov. 14, 1871 J.A. Fay William P. McKee? May. 7, 1872 Baxter D. Whitney Baxter D. Whitney May. 14, 1872 Baxter D. Whitney Baxter D. Whitney May. 21, 1872 J.A. Fay William H. Doane Apr. 8, 1873 Baxter D. Whitney Baxter D. Whitney May. 19, 1874 J.A. Fay William P. McKee? Jul. 13, 1875 Baxter D. Whitney Baxter D. Whitney Aug. 14, 1877 J.A. Fay George W. Bugbee Mar. 19, 1878 J.A. Fay Francis Clark Sep. 4, 1883 Goodell & Waters William G. Vernon Aug. 26, 1884 Goodell & Waters Louis T. Pyott Sep. 1, 1885 L. Power Louis T. Pyott
1837 Baxter D. Whitney 1847 J.A. Fay 1867 L. Power c. 1869 Goodell & Waters c. 1869 Atlantic Works
