Page Revision: 2010/06/28 11:58
front
front
back
The K2200 is a redesign of the 1949 model K2100. Richard Kneisleys design for the earlier model is an elegant and wonderfully engineered machine. It has a power “automatic table adjustment device”. By engaging the clutch the single adjusting screw raises or lowers the table. Final adjusting is done by hand adjusting the 14” center wheel.
The 1949 K2100
pick2100
pick2100 plate
picparts
picelevate screw
picside by side
pic open base
picPulleyside
picgear side
pic pinion
picChipbreaker
picRollers
pictable/no side
picmotor view
