Page Revision: 2010/06/28 14:50
front
front
back
The K2200 is a redesign of the K-Line model K2100 planer. Richard Kneisley's design for the earlier model is an elegant and wonderfully engineered machine. It has a power “automatic table adjustment device”. By engaging the clutch the single adjusting screw raises or lowers the table. Final adjusting is done by hand adjusting the 14” center wheel.
plate
parts
screw
side
sideside
Another inside view with sheet metal covers removed.
pulley side
gear
FORMATTER ERROR (Malformed Image Tag)
Pinion bracket shown on top of casting.
roller
roller2
chip picChipbreaker
Chipbreaker
inside
inside
Inside cabinet view showing motor pulley arrangement
