Page Revision: 2009/04/07 20:52
April 7th, 2009
INDUSTRIAL ENAMEL | ALKYD |
GLOSS | IFC 411X |
BAC COLORANT | OZ | 32 | 64 | 128 |
B1- Black | 4 | 7 | 1 | 1 |
Y3- Deep Gold | - | 4 | 1 | 1 |
DEEP BASE
Quantity: 1 QUART
Keith O'Boyle, Nov 21, 2007
