Page Revision: 2016/07/13 12:26
I thought I'd update this info a bit since paint stores change their formulas over time. When I tried to use some of the info on this page to get paint for my 1946 Unisaw in 2015, Sherwin Williams couldn't use the outdated info. So, I had them do a custom color match with their current deep base alkyd enamel using the undisturbed original paint under the little cover plate behind the tilt hand wheel, then I paid extra ($7/can before promo discount) to have them put the custom-mixed quart into 6 aerosol (rattle) cans. In my opinion, these rattle cans sprayed much better than the Rustoleum spray I've used. The paint came out in a broader, more even swath and went on smoothly. It's an expensive option, however, to have the paint put into rattle cans. After that, I invested $35 in a Critter mason jar sprayer that is powered by a consumer-grade air-compressor. Saves a bunch of money is works well for my machines.
My '46 Unisaw thread is here: 1946 Delta Unisaw Rebuild A scanned image of the Sherwin-Williams paint label follows:
Sherwin-Williams 1946 Delta Gray color match (has slight bluish hue)
..Shawn, July 2016
For those who want to restore or just color match panels or parts for your Delta Machinery, lots of luck trying to get it from Delta. While Rustoleum Dark Machinery Gray #7587 is easier to get, the color is still not a good match. Today I went to my local Sherwin-Williams store and brought in a color sample. I found what I needed right on the shelf. In 12 oz spray cans look for High Seas Gray #650094014 - $4.76 per can. Its an exact match to the Delta Gray/green I have on my Delta Table saw I purchased back in 1999.
-Gino Roth, January 2011
-Curt Blank, April 7th, 2009
Another popular choice is to just use plain old . It is so close match to the original that even an expert could probably not tell them apart.
INDUSTRIAL ENAMELALKYD
GLOSSIFC 411X
BAC COLORANTOZ3264128
B1- Black4711
Y3- Deep Gold-411
DEEP BASE
Quantity: 1 QUART
Keith O'Boyle, Nov 21, 2007
