Page Revision: 2009/02/10 11:08
Powermatic changed their serial numbering system several times over the years, and the timing varied depending on the type of machine. Therefore, interpreting a serial number requires knowledge of the machine type.
Single-End Tenoners
Format | Years | Comments |
| | Model 2 |
| 1948 to 1953 | This model did not have serial numbers. |
| | Model 2A |
N-nnnn | 1955 to 1964 | The "N" is the units digit of the year, beginning in 1955. The "nnnn" is the number of the machine for that year. |
6N-nnnn | 1965 to 1968 | The "N" is the units digit of the year, beginning in 1965. The "nnnn" is the number of the machine for that year. |
N28-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
NN32-nnnn | 1978 to ???? | The "NN" is the last two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
Mortisers
| | Model 2A Chain |
| | Model 15 Chain |
2nnn | 1953 to 1955 | The "nnn" is the number of the machine within this version. |
| 1956 to 1960 | This model did not have serial numbers. |
| 1960 to ???? | This model did not have serial numbers. |
| | Model 10 Hollow Chisel |
2nnn | 1948 to 1955 | The "nnn" is the number of the machine within this version. Beginning year (1948) is estimated. |
N32-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
Wood Lathes
===Jointers===
Scroll Saws
===Spindle Shaper===
Sanders¶
===Drill Presses===
Tilting Arbor Saw
===Wood-cutting Band Saws===
Metal-cutting Band Saws¶
===Planers===
