Page Revision: 2009/02/12 12:58
Format | Years | Comments |
mnnn | 1953—55 | "m" is a digit that varied according to machine type. "nnn" is the number of the machine within this series. |
N-nnnn | 1955—64 | "N" is the unit digit of the year, beginning in 1955. "nnnn" is the number of the machine for that year. |
6N-nnnn | 1965—68 | "N" is the unit digit of the year, beginning in 1965. "nnnn" is the number of the machine for that year. |
NMM-nnnn | 1968—77 | "N" is the unit digit of the year, beginning in 1968. |
NNMM-nnnn | 1968—?? | "NN" is the last two digits of the year, beginning in 1978. |
Examples
serial number 3451. According to the table under "Jointers", below, the model 60 used the pattern "3nnn" during the period 1953 to 1955.
Another Model 60 jointer has
serial number 8-3932, which matches the pattern "N-nnnn", placing it between 1958 and 1967; "N" is 8 so this jointer was made in 1958.
Wood-cutting Band Saws¶
| | Model 80 |
N-nnnn | 1955—?? | "N" is the units digit of the year, beginning in 1955. "nnnn" is the number of the machine for that year. |
| | Model 81 |
N-nnnn | 1960—68 | "N" is the units digit of the year, beginning in 1960. "nnnn" is the number of the machine for that year. |
N81-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
NN81-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
| | Model 140 |
| | Model 141 |
N-nnnn | 1961—68 | "N" is the units digit of the year, beginning in 1955. "nnnn" is the number of the machine for that year. |
N41-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
NN41-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
Metal-cutting Band Saws¶
| | Model 2 |
N-nnnn | 1965—68 | "N" is the units digit of the year, beginning in 1965. "nnnn" is the number of the machine for that year. |
N02-nnnn | 1968—?? | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
| | Model 5 |
N-nnnn | 1964—68 | "N" is the units digit of the year, beginning in 1964. "nnnn" is the number of the machine for that year. |
N05-nnnn | 1968—?? | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
| | Model 6 |
N06-nnnn | 1970—?? | "N" is the units digit of the year, beginning in 1970. "nnnn" is the number of the machine for that year. |
| | Model 8 |
N08-nnnn | 1968—?? | "N" is the units digit of the year, beginning in 1970. "nnnn" is the number of the machine for that year. |
| | Model 83 (Friction cutting) |
| | No serial numbers. |
| | Model 85 |
| | Model 86 |
N-nnn | 1959—?? | "N" is the units digit of the year, beginning in 1959. "nnn" is the number of the machine for that year. |
| | Model 87 |
N87-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
NN87-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
| | Model 88 |
N88-nnnn | 1974—78 | "N" is the units digit of the year, beginning in 1974. "nnnn" is the number of the machine for that year. |
NN88-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
| | Model 89 |
N89-nnnn | 1969—?? | "N" is the units digit of the year, beginning in 1969. "nnnn" is the number of the machine for that year. |
Drill Presses
| | Model 1100 |
N-nnnn | 1965—?? | "nnnn" is the number of the machine in the series. |
| | Model 1150 |
N-0nnn | 1964—68 | "nnnn" is the number of the machine in the series. |
N15X-nnnn | 1968—76 | "N" is the units digit of the year, beginning in 1968. "X" is the letter V or S. "nnnn" is the number of the machine for that year. |
| | Model 1150A |
N15X-nnnn | 1976—78 | "N" is the units digit of the year, beginning in 1976. "X" is the letter V or S. "nnnn" is the number of the machine for that year. |
NN15X-nnnn | 1978—78 | "NN" is the last two digits of the year, beginning in 1978. "X" is the letter V or S. "nnnn" is the number of the machine for that year. |
| | Model 1200 |
N-1nnn | 1955—64 | "nnnn" is the number of the machine in the series. |
NN-nnnn | 1965—68 | "NN" is the last two digits of the year, beginning in 1965. "nnnn" is the number of the machine for that year. |
N20X-nnnn | 1976—78 | "N" is the units digit of the year, beginning in 1976. "X" is the letter V or S. "nnnn" is the number of the machine for that year. |
NN20X-nnnn | 1978—78 | "NN" is the last two digits of the year, beginning in 1978. "X" is the letter V or S. "nnnn" is the number of the machine for that year. |
Jointers
| | Model 50 (6 inch) |
11nnn | 1955—60 | "nnn" is the number of the machine in the series. |
N-nnnn | 1960—65 | "N" is the units digit of the year, beginning in 1960. "nnn" is the number of the machine for that year. |
6N-nnnn | 1965—68 | "N" is the units digit of the year, beginning in 1965. "nnnn" is the number of the machine for that year. |
N50-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
NN50-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
| | Model 60 (8 inch) |
3nnn | 1957 | "nnnn" is the number of the machine within this version. |
N-nnnn | 1958—67 | "N" is the units digit of the year, beginning in 1958. "nnnn" is the number of the machine within this version. |
N61-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
NN61-nnnn | 1978—?? | "NN" is the first two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
Wood Lathes
| | Model 45 |
N-1nnn | 1960—68 | "N" is the units digit of the year, beginning in 1960. "nnn" is the number of the machine for that year. |
N45-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
NN45-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
| | Model 90 |
0-nnnn | 1955—68 | "nnnn" is the number of the machine within this version. |
N90-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
NN90-nnnn | 1978—?? | "NN" is the first two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
Mortisers
| | Model 2A Chain |
| | Model 15 Chain |
2nnn | 1953—55 | "nnn" is the number of the machine within this version. |
N-nnnn | 1955—64 | "N" is the units digit of the year, beginning in 1955. "nnnn" is the number of the machine for that year. |
| | Model 10 Hollow Chisel |
2nnn | 1948—55 | "nnn" is the number of the machine within this version. Beginning year (1948) is estimated. |
N40-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
NN40-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
Planers
| | Model 12 (12 inch) |
nnnn | 1950—?? | "nnnn" is the number of the machine in the series. |
| | Models CD 16, CE 16, CS 16 (16 inch) |
| | Model E 16 (16 inch) |
nnnn | 19??—?? | "nnnn" is the number of the machine in the series, beginning with 7001. |
| | Model 100 (12 inch) |
nnnn | 1955—55 | "nnnn" is the number of the machine in the series, beginning with 6200. |
N00-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
NN00-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
| | Model 160 (16 inch) |
N-nnnn | 1959—67 | "N" is the units digit of the year, beginning in 1959. "nnnn" is the number of the machine for that year. |
N60-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
NN60-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
| | Model 180 (18 inch) |
N-nnn | 1961—68 | "N" is the units digit of the year, beginning in 1961. "nnn" is the number of the machine for that year. |
N80-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
NN80-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
Sanders¶
| | Model 30 |
N30-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
| | Model 30A |
N30Annnn | 1969—77 | "N" is the units digit of the year, beginning in 1969. "nnn" is the number of the machine for that year. |
NN30-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
| | Model 30B |
| | Model 33 |
N33-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
| | Model 33B |
NN33-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
| | Model 35 |
N35-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
| | Model 35B |
NN35-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
Scroll Saws
| | Model 95 |
N-nnn | 1961—68 | "N" is the units digit of the year, beginning in 1961. "nnnn" is the number of the machine for that year. |
N95-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
NN95-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
Spindle Shaper
| | Model 25 |
N-nnnn | 1961—65 | "N" is the units digit of the year, beginning in 1955. "nnnn" is the number of the machine for that year. |
| | Model 26 |
N26-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
NN26-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
Tilting Arbor Saw (Tablesaw)
| | Model 62 |
N-nnn | 1964—68 | "N" is the units digit of the year, beginning in 1964. "nnn" is the number of the machine for that year. |
N62-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
NN62-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
| | Model 65 |
N-nnn | 1955—65 | "N" is the units digit of the year, beginning in 1955. "nnn" is the number of the machine for that year. |
NN-nnn | 1965—?? | "NN" is the last two digits of the year, beginning in 1965. "nnn" is the number of the machine for that year. |
| | Model 66 |
66-nnn | 1965—68 | "nnn" is the number of the machine for the series. |
N66-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
NN66-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
| | Model 68 |
N68-nnnn | 1972—78 | "N" is the units digit of the year, beginning in 1972. "nnnn" is the number of the machine for that year. |
NN68-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
| | Model 70 |
1nnn | 1954—55 | "nnn" is the number of the machine for the series. |
N-nnnn | 1955—60 | "nnnn" is the number of the machine in the series. |
| | Model 71 |
N-nnn | 1960—?? | "N" is the units digit of the year, beginning in 1960. "nnn" is the number of the machine in the series (beginning with "600" in 1960). |
| | Model 72 |
N-nnn | 1958—67 | "N" is the units digit of the year, beginning in 1958. "nnn" is the number of the machine in the series. |
N72-nnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnn" is the number of the machine in the series. |
NN72-nnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnn" is the number of the machine in the series. |
Single-End Tenoners
| | Model 2 |
| | Model 2A |
N28-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine for that year. |
NN32-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine for that year. |
