Page Revision: 2009/02/13 13:41
Format | Years | Comments |
mnnn | 1953—55 | "m" is a digit that varied according to machine type. "nnn" is the number of the machine within this series. |
N-nnnn | 1955—64 | "N" is the units digit of the year, beginning in 1955. "nnnn" is the number of the machine. |
6N-nnnn | 1965—68 | "N" is the units digit of the year, beginning in 1965. "nnnn" is the number of the machine. |
NMM-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. |
NNMM-nnnn | 1968—?? | "NN" is the last two digits of the year, beginning in 1978. |
Examples
serial number 3451. According to the table under "Jointers", below, the model 60 used the pattern "3nnn" during the period 1953 to 1955.
Another Model 60 jointer has
serial number 8-3932, which matches the pattern "N-nnnn", placing it between 1958 and 1967; "N" is 8 so this jointer was made in 1958.
Band Saws, Wood-Cutting¶
| | Model 80 |
N-nnnn | 1955—?? | "N" is the units digit of the year, beginning in 1955. "nnnn" is the number of the machine. |
| | Model 81 |
N-nnnn | 1960—68 | "N" is the units digit of the year, beginning in 1960. "nnnn" is the number of the machine. |
N81-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN81-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
| | Model 140 |
| | Model 141 |
N-nnnn | 1961—68 | "N" is the units digit of the year, beginning in 1955. "nnnn" is the number of the machine. |
N41-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN41-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
Band Saws, Metal-cutting¶
| | Model 2 |
N02-nnnn | 1968—?? | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
| | Model 5 |
N-nnnn | 1964—68 | "N" is the units digit of the year, beginning in 1964. "nnnn" is the number of the machine. |
N05-nnnn | 1968—?? | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
| | Model 6 |
N06-nnnn | 1970—?? | "N" is the units digit of the year, beginning in 1970. "nnnn" is the number of the machine. |
| | Model 8 |
N08-nnnn | 1968—?? | "N" is the units digit of the year, beginning in 1970. "nnnn" is the number of the machine. |
| | Model 83 (Friction cutting) |
| | No serial numbers. |
| | Model 85 |
| | Model 86 |
N-nnn | 1959—?? | "N" is the units digit of the year, beginning in 1959. "nnn" is the number of the machine. |
| | Model 87 |
N87-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN87-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
| | Model 88 |
N88-nnnn | 1974—78 | "N" is the units digit of the year, beginning in 1974. "nnnn" is the number of the machine. |
NN88-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
| | Model 89 |
N89-nnnn | 1969—?? | "N" is the units digit of the year, beginning in 1969. "nnnn" is the number of the machine. |
Drill Presses
| | Model 1100 |
N-nnnn | 1955—63 | "N" is the units digit of the year, beginning in 1955. "nnnn" is the number of the machine. |
| | Model 1150 |
N-0nnn | 1964—68 | "N" is the units digit of the year, beginning in 1964. "nnnn" is the number of the machine. |
N15X-nnnn | 1968—76 | "N" is the units digit of the year, beginning in 1968. "X" is the letter V or S. "nnnn" is the number of the machine. |
| | Model 1150A |
N15X-nnnn | 1976—78 | "N" is the units digit of the year, beginning in 1976. "X" is the letter V or S. "nnnn" is the number of the machine. |
NN15X-nnnn | 1978—78 | "NN" is the last two digits of the year, beginning in 1978. "X" is the letter V or S. "nnnn" is the number of the machine. |
| | Model 1200 |
N-1nnn | 1955—64 | "nnnn" is the number of the machine. |
NN-nnnn | 1965—68 | "NN" is the last two digits of the year, beginning in 1965. "nnnn" is the number of the machine. |
N20X-nnnn | 1976—78 | "N" is the units digit of the year, beginning in 1976. "X" is the letter V or S. "nnnn" is the number of the machine. |
NN20X-nnnn | 1978—78 | "NN" is the last two digits of the year, beginning in 1978. "X" is the letter V or S. "nnnn" is the number of the machine. |
Jointers
| | Model 50 (6 inch) |
11nnn | 1955—60 | "nnn" is the number of the machine. |
N-nnnn | 1960—65 | "N" is the units digit of the year, beginning in 1960. "nnn" is the number of the machine. |
N50-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN50-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
| | Model 60 (8 inch) |
3nnn | 1957 | "nnnn" is the number of the machine within this version. |
N-nnnn | 1958—67 | "N" is the units digit of the year, beginning in 1958. "nnnn" is the number of the machine within this version. |
N61-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN61-nnnn | 1978—?? | "NN" is the first two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
Lathes, Wood
| | Model 45 |
N-1nnn | 1960—68 | "N" is the units digit of the year, beginning in 1960. "nnn" is the number of the machine. |
N45-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN45-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
| | Model 90 |
0-nnnn | 1955—68 | "nnnn" is the number of the machine within this version. |
N90-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN90-nnnn | 1978—?? | "NN" is the first two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
Mortisers
| | Model 2A Chain |
| | Model 15 Chain |
2nnn | 1953—55 | "nnn" is the number of the machine within this version. |
| | Model 10 Hollow Chisel |
2nnn | 1948—55 | "nnn" is the number of the machine within this version. Beginning year (1948) is estimated. |
N40-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN40-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
Planers
| | Model 2A (20 inch) |
| | Model 3A (24 inch) |
| | Model 12 (12 inch) |
nnnn | 1950—?? | "nnnn" is the number of the machine. |
| | Models CD 16, CE 16, CS 16 (16 inch) |
| | Model E 16 (16 inch) |
nnnn | 19??—?? | "nnnn" is the number of the machine, beginning with 7001. |
| | Model 100 (12 inch) |
nnnn | 1955—55 | "nnnn" is the number of the machine, beginning with 6200. |
N00-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN00-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
| | Model 160 (16 inch) |
N-nnnn | 1959—67 | "N" is the units digit of the year, beginning in 1959. "nnnn" is the number of the machine. |
N60-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN60-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
| | Model 180 (18 inch) |
N-nnn | 1961—68 | "N" is the units digit of the year, beginning in 1961. "nnn" is the number of the machine. |
N80-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN80-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
| | Model 220 (20 inch) |
nnnn | 1952—55 | "nnnn" is the number of the machine, beginning with number 5100. |
| | Model 221 (20 inch) |
N-nnnn | 1955—64 | "N" is the units digit of the year, beginning in 1955. "nnnn" is the number of the machine, beginning with 5525. |
6N-nnnn | 1965—67 | "N" is the units digit of the year, beginning in 1965. "nnnn" is the number of the machine. |
N22-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN22-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
| | Model 224 (24 inch) |
nnnn | 1955—57 | "nnnn" is the number of the machine, beginning with number 8001. |
| | Model 225 (24 inch) |
nnnn | 1957—60 | "nnnn" is the number of the machine, beginning with number 8360. |
N-nnnn | 1960—67 | "N" is the units digit of the year, beginning in 1965. "nnnn" is the number of the machine. |
N25-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN25-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
Sanders¶
| | Model 30 |
N30-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
| | Model 30A |
N30Annnn | 1969—77 | "N" is the units digit of the year, beginning in 1969. "nnn" is the number of the machine. |
NN30-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
| | Model 30B |
| | Model 33 |
N33-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
| | Model 33B |
NN33-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
| | Model 35 |
N35-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
| | Model 35B |
NN35-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
Scroll Saws
| | Model 95 |
N-nnn | 1961—68 | "N" is the units digit of the year, beginning in 1961. "nnnn" is the number of the machine. |
N95-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN95-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
Spindle Shaper
| | Model 25 |
N-nnnn | 1961—65 | "N" is the units digit of the year, beginning in 1955. "nnnn" is the number of the machine. |
| | Model 26 |
N26-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN26-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
Tilting Arbor Saw (Tablesaw)
| | Model 62 |
N-nnn | 1964—68 | "N" is the units digit of the year, beginning in 1964. "nnn" is the number of the machine. |
N62-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN62-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
| | Model 65 |
N-nnn | 1955—65 | "N" is the units digit of the year, beginning in 1955. "nnn" is the number of the machine. |
NN-nnn | 1965—?? | "NN" is the last two digits of the year, beginning in 1965. "nnn" is the number of the machine. |
| | Model 66 |
66-nnn | 1965—68 | "nnn" is the number of the machine for the series. |
N66-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN66-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
| | Model 68 |
N68-nnnn | 1972—78 | "N" is the units digit of the year, beginning in 1972. "nnnn" is the number of the machine. |
NN68-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
| | Model 70 |
1nnn | 1954—55 | "nnn" is the number of the machine for the series. |
N-nnnn | 1955—60 | "nnnn" is the number of the machine. |
| | Model 71 |
N-nnn | 1960—?? | "N" is the units digit of the year, beginning in 1960. "nnn" is the number of the machine, beginning with "600" in 1960. |
| | Model 72 |
N-nnn | 1958—67 | "N" is the units digit of the year, beginning in 1958. "nnn" is the number of the machine. |
N72-nnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnn" is the number of the machine. |
NN72-nnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnn" is the number of the machine. |
Tenoners, Single-End
| | Model 2 |
| | Model 2A |
N28-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is the number of the machine. |
NN32-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is the number of the machine. |
