Page Revision: 2010/09/25 16:29
Format | Years | Comments |
mnnn | 1953—55 | "m" is a digit that varied according to machine type. "nnn" is a number. |
N-nnnn | 1955—64 | "N" is the units digit of the year, beginning in 1955. "nnnn" is a number. |
6N-nnnn | 1965—68 | "N" is the units digit of the year, beginning in 1965. "nnnn" is a number. |
NMM-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NNMM-nnnn | 1968—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
Examples
Another Model 60 jointer has
Caveats
Band Saws, Wood-Cutting¶
| | Model 80 |
N-nnnn | 1955—?? | "N" is the units digit of the year, beginning in 1955. "nnnn" is a number. |
| | Model 81 |
N-nnnn | 1960—68 | "N" is the units digit of the year, beginning in 1960. "nnnn" is a number. |
N81-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN81-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| | Model 140 |
| | Model 141 |
N-nnnn | 1961—68 | "N" is the units digit of the year, beginning in 1955. "nnnn" is a number. |
N41-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN41-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
Band Saws, Metal-cutting¶
| | Model 2 |
N02-nnnn | 1968—?? | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| | Model 5 |
N-nnnn | 1964—68 | "N" is the units digit of the year, beginning in 1964. "nnnn" is a number. |
N05-nnnn | 1968—?? | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| | Model 6 |
N06-nnnn | 1970—?? | "N" is the units digit of the year, beginning in 1970. "nnnn" is a number. |
| | Model 8 |
N08-nnnn | 1968—?? | "N" is the units digit of the year, beginning in 1970. "nnnn" is a number. |
| | Model 83 (Friction cutting) |
| | No serial numbers. |
| | Model 85 |
| | Model 86 |
N-nnn | 1959—?? | "N" is the units digit of the year, beginning in 1959. "nnn" is a number. |
| | Model 87 |
N87-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN87-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| | Model 88 |
N88-nnnn | 1974—78 | "N" is the units digit of the year, beginning in 1974. "nnnn" is a number. |
NN88-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| | Model 89 |
N89-nnnn | 1969—?? | "N" is the units digit of the year, beginning in 1969. "nnnn" is a number. |
Drill Presses
| | Model 1100 |
N-nnnn | 1955—63 | "N" is the units digit of the year, beginning in 1955. "nnnn" is a number. |
| | Model 1150 |
N-0nnn | 1964—68 | "N" is the units digit of the year, beginning in 1964. "nnnn" is a number. |
N15X-nnnn | 1968—76 | "N" is the units digit of the year, beginning in 1968. "X" is the letter V or S. "nnnn" is a number. |
| | Model 1150A |
N15X-nnnn | 1976—78 | "N" is the units digit of the year, beginning in 1976. "X" is the letter V or S. "nnnn" is a number. |
NN15X-nnnn | 1978—78 | "NN" is the last two digits of the year, beginning in 1978. "X" is the letter V or S. "nnnn" is a number. |
| | Model 1200 |
N-1nnn | 1955—64 | "nnnn" is a number. |
NN-nnnn | 1965—68 | "NN" is the last two digits of the year, beginning in 1965. "nnnn" is a number. |
N20X-nnnn | 1976—78 | "N" is the units digit of the year, beginning in 1976. "X" is the letter V or S. "nnnn" is a number. |
NN20X-nnnn | 1978—78 | "NN" is the last two digits of the year, beginning in 1978. "X" is the letter V or S. "nnnn" is a number. |
Jointers
| | Model 50 (6 inch) |
11nnn | 1955—60 | "nnn" is a number. |
N-nnnn | 1960—65 | "N" is the units digit of the year, beginning in 1960. "nnn" is a number. |
N50-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN50-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| | Model 60 (8 inch) |
3nnn | 1957—1960 | "nnn" is a number. |
N-nnnn | 1960—68 | "N" is the units digit of the year, beginning in 1958. "nnnn" is a number. |
N61-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN61-nnnn | 1978—?? | "NN" is the first two digits of the year, beginning in 1978. "nnnn" is a number. |
Lathes, Wood
| | Model 45 |
N-1nnn | 1960—65? | "N" is the units digit of the year, beginning in 1960. "nnn" is a number. |
N45-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN45-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| | Model 90 |
0-nnnn | 1955—68 | "nnnn" is a number. |
N90-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN90-nnnn | 1978—?? | "NN" is the first two digits of the year, beginning in 1978. "nnnn" is a number. |
Mortisers
| | Model 2A Chain |
| | Model 15 Chain |
2nnn | 1953—55 | "nnn" is a number. |
| | Model 10 Hollow Chisel |
2nnn | 1948—55 | "nnn" is a number. Beginning year (1948) is estimated. |
N40-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN40-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
Planers
| | Model 2A (20 inch) |
| | Model 3A (24 inch) |
| | Model 12 (12 inch) |
nnnn | 1950—?? | "nnnn" is a number. |
| | Models CD 16, CE 16, CS 16 (16 inch) |
| | Model E 16 (16 inch) |
nnnn | 19??—?? | "nnnn" is a number, beginning with 7001. |
| | Model 100 (12 inch) |
nnnn | 1955—55 | "nnnn" is a number, beginning with 6200. |
N00-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN00-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| | Model 160 (16 inch) |
N-nnnn | 1959—67 | "N" is the units digit of the year, beginning in 1959. "nnnn" is a number. |
N60-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN60-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| | Model 180 (18 inch) |
N-nnn | 1961—68 | "N" is the units digit of the year, beginning in 1961. "nnn" is a number. |
N80-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN80-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| | Model 220 (20 inch) |
nnnn | 1952—55 | "nnnn" is a number, beginning with number 5100. |
| | Model 221 (20 inch) |
N-nnnn | 1955—64 | "N" is the units digit of the year, beginning in 1955. "nnnn" is a number, beginning with 5525. |
6N-nnnn | 1965—67 | "N" is the units digit of the year, beginning in 1965. "nnnn" is a number. |
N22-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN22-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| | Model 224 (24 inch) |
nnnn | 1955—57 | "nnnn" is a number, beginning with number 8001. |
| | Model 225 (24 inch) |
nnnn | 1957—60 | "nnnn" is a number, beginning with number 8360. |
N-nnnn | 1960—67 | "N" is the units digit of the year, beginning in 1965. "nnnn" is a number. |
N25-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN25-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
Sanders¶
| | Model 30 |
N30-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| | Model 30A |
N30Annnn | 1969—77 | "N" is the units digit of the year, beginning in 1969. "nnn" is a number. |
NN30-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| | Model 30B |
| | Model 33 |
N33-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| | Model 33B |
NN33-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| | Model 35 |
N35-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
| | Model 35B |
NN35-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
Scroll Saws
| | Model 95 |
N-nnn | 1961—68 | "N" is the units digit of the year, beginning in 1961. "nnnn" is a number. |
N95-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN95-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
Spindle Shaper
| | Model 25 |
N-nnnn | 1961—65 | "N" is the units digit of the year, beginning in 1955. "nnnn" is a number. |
| | Model 26 |
N26-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN26-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
Tilting Arbor Saw (Tablesaw)
| | Model 62 |
N-nnn | 1964—68 | "N" is the units digit of the year, beginning in 1964. "nnn" is a number. |
N62-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN62-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| | Model 65 |
N-nnn | 1955—65 | "N" is the units digit of the year, beginning in 1955. "nnn" is a number. |
NN-nnn | 1965—?? | "NN" is the last two digits of the year, beginning in 1965. "nnn" is a number. |
| | Model 66 |
66-nnn | 1965—68 | "nnn" is a number. |
N66-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN66-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| | Model 68 |
N68-nnnn | 1972—78 | "N" is the units digit of the year, beginning in 1972. "nnnn" is a number. |
NN68-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
| | Model 70 |
1nnn | 1954—55 | "nnn" is a number. |
N-nnnn | 1955—60 | "nnnn" is a number. |
| | Model 71 |
N-nnn | 1960—?? | "N" is the units digit of the year, beginning in 1960. "nnn" is a number, beginning with "600" in 1960. |
| | Model 72 |
N-nnn | 1958—67 | "N" is the units digit of the year, beginning in 1958. "nnn" is a number. |
N72-nnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnn" is a number. |
NN72-nnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnn" is a number. |
Tenoners, Single-End
| | Model 2 |
| | Model 2A |
N28-nnnn | 1968—77 | "N" is the units digit of the year, beginning in 1968. "nnnn" is a number. |
NN32-nnnn | 1978—?? | "NN" is the last two digits of the year, beginning in 1978. "nnnn" is a number. |
