Page Revision: 2009/02/11 14:32
Format | Years | Comments |
| 1948 to 1953 | Early machines did not have serial numbers. |
mnnn | 1953 to 1955 | "m" is a digit that varied according to machine type. "nnn" is the number of the machine within this series. |
N-nnnn | 1955 to 1964 | "N" is the unit digit of the year, beginning in 1955. "nnnn" is the number of the machine for that year. |
6N-nnnn | 1965 to 1968 | "N" is the unit digit of the year, beginning in 1965. "nnnn" is the number of the machine for that year. |
NMM-nnnn | 1968 to 1977 | "N" is the unit digit of the year, beginning in 1968. |
NNMM-nnnn | 1968 to ???? | "NN" is the last two digits of the year, beginning in 1978. |
Single-End Tenoners
| | Model 2 |
| 1948 to 1953 | This model did not have serial numbers. |
| | Model 2A |
N-nnnn | 1955 to 1964 | The "N" is the units digit of the year, beginning in 1955. The "nnnn" is the number of the machine for that year. |
6N-nnnn | 1965 to 1968 | The "N" is the units digit of the year, beginning in 1965. The "nnnn" is the number of the machine for that year. |
N28-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
NN32-nnnn | 1978 to ???? | The "NN" is the last two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
Mortisers
| | Model 2A Chain |
| | Model 15 Chain |
2nnn | 1953 to 1955 | The "nnn" is the number of the machine within this version. |
| 1956 to 1960 | This model did not have serial numbers. |
| 1960 to ???? | This model did not have serial numbers. |
| | Model 10 Hollow Chisel |
2nnn | 1948 to 1955 | The "nnn" is the number of the machine within this version. Beginning year (1948) is estimated. |
N40-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
NN40-nnnn | 1978 to ???? | The "NN" is the last two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
Wood Lathes
| | Model 45 |
N-1nnn | 1960 to 1968 | The "N" is the units digit of the year, beginning in 1960. The "nnn" is the number of the machine for that year. |
N45-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
NN45-nnnn | 1978 to ???? | The "NN" is the last two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
| | Model 90 |
0-nnnn | 1955 to 1968 | The "nnnn" is the number of the machine within this version. |
N90-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
NN90-nnnn | 1978 to ???? | The "NN" is the first two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
Jointers
| | Model 50 (6 inch) |
11nnn | 1955 to 1960 | "nnn" is the number of the machine in the series. |
N-nnnn | 1960 to 1965 | The "N" is the units digit of the year, beginning in 1960. The "nnn" is the number of the machine for that year. |
N50-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
NN50-nnnn | 1978 to ???? | The "NN" is the last two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
| | Model 60 (8 inch) |
3nnn | 1957 to 1960 | The "nnnn" is the number of the machine within this version. |
N-nnnn | 1960 to 1968 | The "N" is the units digit of the year, beginning in 1960. The "nnnn" is the number of the machine within this version. |
N61-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
NN61-nnnn | 1978 to ???? | The "NN" is the first two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
Scroll Saws
| | Model 95 |
N-nnn | 1961 to 1968 | The "N" is the units digit of the year, beginning in 1961. The "nnnn" is the number of the machine for that year. |
N95-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
NN95-nnnn | 1978 to ???? | The "NN" is the last two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
Spindle Shaper
| | Model 25 |
N-nnnn | 1961 to 1965 | The "N" is the units digit of the year, beginning in 1955. The "nnnn" is the number of the machine for that year. |
| | Model 26 |
N26-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
NN26-nnnn | 1978 to ???? | The "NN" is the last two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
Sanders¶
| | Model 30 |
N-nnnn | 1960 to 1968 | The "N" is the units digit of the year, beginning in 1960. The "nnnn" is the number of the machine for that year. |
N30-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
| | Model 30A |
N30Annnn | 1969 to 1977 | The "N" is the units digit of the year, beginning in 1969. The "nnn" is the number of the machine for that year. |
NN30-nnnn | 1978 to ???? | The "NN" is the last two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
| | Model 30B |
| | Model 33 |
N33-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
| | Model 33B |
NN33-nnnn | 1978 to ???? | The "NN" is the last two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
| | Model 35 |
N35-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
| | Model 35B |
NN35-nnnn | 1978 to ???? | The "NN" is the last two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
Drill Presses
| | Model 1100 |
N-nnnn | 1965 to ???? | "nnnn" is the number of the machine in the series. |
| | Model 1150 |
N-0nnn | 1964 to 1968 | "nnnn" is the number of the machine in the series. |
N15X-nnnn | 1968 to 1976 | "N" is the units digit of the year, beginning in 1968. "X" is the letter V or S. "nnnn" is the number of the machine for that year. |
| | Model 1150A |
N15X-nnnn | 1976 to 1978 | "N" is the units digit of the year, beginning in 1976. "X" is the letter V or S. "nnnn" is the number of the machine for that year. |
NN15X-nnnn | 1978 to 1978 | "NN" is the last two digits of the year, beginning in 1978. "X" is the letter V or S. "nnnn" is the number of the machine for that year. |
| | Model 1200 |
N-1nnn | 1955 to 1964 | "nnnn" is the number of the machine in the series. |
NN-nnnn | 1965 to 1968 | "NN" is the last two digits of the year, beginning in 1965. "nnnn" is the number of the machine for that year. |
N20X-nnnn | 1976 to 1978 | "N" is the units digit of the year, beginning in 1976. "X" is the letter V or S. "nnnn" is the number of the machine for that year. |
NN20X-nnnn | 1978 to 1978 | "NN" is the last two digits of the year, beginning in 1978. "X" is the letter V or S. "nnnn" is the number of the machine for that year. |
Tilting Arbor Saw
| | Model X |
Xnnnn | 1953 to 1955 | "nnnn" is the number of the machine in the series. |
NXX-nnnn | 1968 to 1977 | The "N" is the units digit of the year, beginning in 1968. The "nnnn" is the number of the machine for that year. |
NNXX-nnnn | 1978 to ???? | The "NN" is the last two digits of the year, beginning in 1978. The "nnnn" is the number of the machine for that year. |
Wood-cutting Band Saws¶
| | Model X |
Metal-cutting Band Saws¶
| | Model X |
Planers
| | Model X |
