Page Revision: 2010/01/05 13:02
- This list contains ball bearing information for machines sold by Sears.
- Original Bearings: ?
- Accurate Replacement: none (odd size)
Motors
115.5652 Dunlap 1/3 hp: original-ND USA ENDEE 8013, Accurate replacement-87013
115.6960 Dunlap 1/3 hp: original-ND USA 8013, Accurate replacement-87013
Common Bearing Specs
8013: OD=32mm, ID=13mm, W=10mm, 3mm extended inner race on one side
