Page Revision: 2010/02/06 17:05
Grinder/Polishing Head
- Accurate Replacement: none (odd size)
Craftsman 103.23340 4-3/8"
- Accurate Replacement: R8ZZ
Motor
- Original Bearings: (TBD)
Bearing Specs
