Page Revision: 2010/03/23 12:36
Grinder/Polishing Head
- Accurate Replacement: none (odd size)
- Accurate Replacement: (T.B.D.)
Craftsman 103.23340 4-3/8"
- Accurate Replacement: R8ZZ
Motor
- Original Bearings: (TBD)
Bearing Specs
