Page Revision: 2010/03/24 06:32
Grinder/Polishing Head
- Accurate Replacement: 1622
Craftsman 103.23340 4-3/8"
- Accurate Replacement: R8ZZ
Motor
- Original Bearings: (TBD)
Bearing Specs
