Page Revision: 2010/04/28 23:28
Grinder/Polishing Head
- Accurate Replacement: 1622
Craftsman 103.23340 4-3/8"
- Accurate Replacement: R8ZZ
Motor
115.19020 Craftsman 3/4hp:
113.19040 Craftsman 1 hp: original-Norma (USA) 203PP double shield ; Accurate replacement-6203
- Original Bearings: (TBD)
Sander¶
Bearing Specs
