Page Revision: 2011/01/19 21:24
Grinder/Polishing Head
- Accurate Replacement: 6203
- Accurate Replacement: 87502
- Accurate Replacement: 1622
Craftsman 103.23340 4-3/8"
- Accurate Replacement: R8ZZ
Motor
115.19020 Craftsman 3/4hp:
- Original Bearings: (TBD)
Sander¶
Bearing Specs
