Page Revision: 2013/07/23 08:13
Grinder/Polishing Head
- Accurate Replacement: 87502
- Accurate Replacement: 1622
Craftsman 103.23340 4-3/8"
- Accurate Replacement: R8ZZ
Motor
115.19020 Craftsman 3/4hp:
551.1939-1 Craftsman 1hp:
- Original Bearings: (TBD)
Sander¶
Craftsman 113.23940
Bearing Specs
