Page Revision: 2014/05/22 07:42
Grinder/Polishing Head
- Accurate Replacement: 87502
- Accurate Replacement: 1622
Craftsman 103.0502 4-1/4"
- Accurate Replacement: R8ZZ
- Emerson part number: 18229
115.7429 Craftsman: Accurate replacement-6202-5/8 (double check yours--possibly different brgs over production run), Packard p/n-908502
- Original Bearings: (TBD)
Sander¶
- Emerson part number: 39815
