Page Revision: 2014/06/02 10:27
Band Saw¶
Craftsman (12") 103.24250
Craftsman 103.23100
Craftsman (6") Cat# 2601
- Accurate Replacement: 1622
Craftsman (6") 113.6605
Grinder - 6" Electric
Companion 115.5273
- Accurate Replacement: 87502
Craftsman 115.7561
Craftsman 397.19391
Craftsman 115.19500
- Packard part number: 954832
Craftsman 397.19589
Grinder - 7" Electric
Craftsman 5120 (Cat# 2609)
- Accurate replacement: 6204
Craftsman 115.6965
- Accurate replacement: 87502
Craftsman 115.7575
- Accurate replacement: 6203
Craftsman 397.1949
Grinder - 8" Electric
Craftsman 397.19670
Craftsman (4¼") 103.0502
- Accurate Replacement: R8ZZ
Craftsman (6") 102.05600
Craftsman (6") 103.23320
- Emerson part number: 3509
- Emerson part number: 18229
115.6890 Craftsman: original-ND (USA) 8505; Packard p/n-908505; Accurate replacement-(TBD)
115.7429 Craftsman: Packard p/n-908502; Accurate replacement-87502 (double check yours-one motor reported to have 6202-5/8)
- Original Bearings: (TBD)
Sander¶
- Emerson part number: 39815
