Page Revision: 2022/04/14 06:53
Table of Contents [Hide/Show] Introduction Band Saw Craftsman (10" Deluxe) 103.0101 Craftsman/Dunlap (12") 103.0103 Craftsman (12") 103.24250 Craftsman (12") 103.24280 Craftsman (12") 113.24330 Drill Press Craftsman 103.0303 Craftsman 103.23100 Craftsman 103.23130 Craftsman 103.23640 Craftsman 103.2482x Craftsman 15-inch & 15½-inch Central Specialty & Emerson built USA Bench & Floor Models (excluding Emerson built Commercial models) Craftsman 15½ Emerson built USA Commercial models Grinder/Polishing Head - Belt Driven Craftsman (6") Cat# 2601 Craftsman (Polishing Head) 113.6601 Craftsman (6") 103.6604 (early model) Craftsman (6") 113.6604 (later model) Craftsman (6") 113.6605 Craftsman (8") 109.66110, 109.66130 Craftsman (8") 109.66120 Craftsman (6") 103.6614 Dunlap (Polishing Head) xxx.6643 Craftsman (Polishing Head) 103.6647 Craftsman (6") xxx.6649 Grinder - 6" Electric Companion 115.5273 Craftsman 115.7561 Craftsman 397.19391 Craftsman 115.19500 Craftsman 397.19589 Grinder - 7" Electric Craftsman 5120 (Cat# 2609) Craftsman 115.6965 Craftsman 115.7575 Craftsman 397.1949 Grinder - 8" Electric Craftsman 397.19670 Craftsman 257.192190 Jointer Craftsman (4¼") 103.0502 Craftsman (4⅜") 103.23340, 103.21820, 103.20670, 103.20680 Craftsman (6") 102.05600 Craftsman (6") 103.23900, 103.20660 Craftsman (6") 103.23320 Craftsman (6⅛") 103.20620, 113.20621 Craftsman (6⅛") 113.20650, 113.206801, 113.206933 Lathe Dunlap 534.0601 9x30 Belt Driven Woodworking Lathe Craftsman 101.06260 10x36 Belt Driven Woodworking Lathe Craftsman 101.21400 6x18 Belt Driven Metalworking Lathe Craftsman 103.21600 8x24 Belt Driven Woodworking Lathe Craftsman 113.228000, 103.23880, 113.23881 12x37 tube style bed Motor - 1/3 HP Motor - 1/2 HP Motor - 3/4 HP Motor - 1 HP Motor - 1½ HP Motor - 2 HP Motor - 3 HP Motor - 5 HP Motor - 7½ HP Planer Craftsman 103.1801 6"x2" manual feed Craftsman 103.23700 6"x2" manual feed ROUTER SANDER Craftsman 103.22500 Belt/Disk Shaper Dunlap 534.09760 Craftsman 103.23940, 113.23940 Swing Saw Craftsman 103.25450 Table Saw Craftsman/Atlas 8-inch Tilt-Arbor Craftsman 103.0213 & Dunlap 103.02041 8-inch Tilt-Table Bench Saw Dunlap 103.0214 8-inch Tilt-Table Bench Saw Craftsman 103.2000 9-inch Bench Saw Craftsman 113.1011, 113.22400, 113.29730 8-inch Bench Saw Craftsman 103.2727_ & 113.2245_ 10-inch Floor Saws Craftsman 113.2752_ 10-inch Bench Saw Craftsman 113.2999_ 10-inch Bench Saw Bearing Quick Reference Specs
Band Saw¶
Craftsman 103.0303
Craftsman 103.23100
Craftsman 103.23130
Craftsman 103.2482x
- Accurate replacement: quill-6202 with 5/8" bore double shield (Qty-2), pulley-6205 double shield (Qty-2)
- Accurate replacement: upper quill-6203 double shield, lower quill-5203 double row double shield, pulley-6205 double shield (Qty-2)
- Accurate Replacement: 1622
- Original Bearings: 6202ZZ
Companion 115.5273
- Accurate Replacement: 87502
Craftsman 115.7561
Craftsman 397.19391
Craftsman 115.19500
- Packard part number: 954832
Craftsman 397.19589
- Accurate replacement: 6204
Craftsman 115.6965
- Accurate replacement: 87502
Craftsman 115.7575
- Accurate replacement: 6203
Craftsman 397.1949
Craftsman 397.19670
- Emerson part number: 3509
- Qty=2 ball bearings
- 6203 with special 3/4" bore
- Emerson part number: 18229
- Original Bearings: (TBD)
ROUTER
- Craftsman 315.25031: upper-Hoover WCB7500RS, lower-Hoover D7202 (seal-outer, shield inner)
SANDER¶
Dunlap 534.09760
- Central Specialty/Emerson part number: 39815
- Possibly a tighter than C3 clearance ball bearing
