Page Revision: 2014/05/22 10:41
Band Saw¶
Craftsman/Dunlap 103.0103
Grinder/Polishing Head
- Accurate Replacement: 87502
- Accurate Replacement: 1622
Craftsman (4¼") 103.0502
4-3/8" 103.23340, 103.21820, 103.20670, 103.20680
- Accurate Replacement: R8ZZ
6" 103.23900, 103.20660
6" 103.23320
6-1/8" 103.20620, 113.20621
6-1/8" 113.20650, 113.206801, 113.206801, 113.206933
- Emerson part number: 3509
- •Accurate replacement: 6202ZZ-5/8 (double shields) or 6202LL-5/8 (double seals)
- Emerson part number: 18229
- Original Bearings: (TBD)
Sander¶
- Emerson part number: 39815
