Page Revision: 2014/05/27 14:06
Band Saw¶
Craftsman (12") 103.24250
Craftsman 103.23100
Craftsman (6") Cat# 2601
Craftsman (6") 103.6604
- Accurate Replacement: 1622
Craftsman (6") 113.6604
Craftsman (6") 113.6605
Grinder - 6" Electric
Companion 115.5273
- Accurate Replacement: 87502
Craftsman 115.7561
Craftsman 397.19391
Craftsman 115.19500
- Packard part number: 954832
Craftsman 397.19589
Grinder - 7" Electric
Craftsman 115.6965
Craftsman 115.7575
Grinder - 8" Electric
Craftsman 397.19670
Craftsman (4¼") 103.0502
- Accurate Replacement: R8ZZ
Craftsman (6") 102.05600
Craftsman (6") 103.23320
- Emerson part number: 3509
- Emerson part number: 18229
- Original Bearings: (TBD)
Sander¶
- Emerson part number: 39815
