Page Revision: 2009/01/17 21:33
- 1. The first serial number system began in 1939. These followed no logical pattern and were more akin to a model number than a unit-specific designation. See the machine-specific section below for details.
A | Tilting Arbor & Table Saw | | G | Grinder |
B | Band Saw | | J | Jig Saw |
C | Sander | | L | Lathes |
D | 15” Drill Press | | P | Planer (Jointer) |
E | 20” Drill Press | | R | Radial Saw & Drill |
| | | S | Spindle Shaper |
- 4. The last serial number system began in October of 1956. The machine type is designated by a two-digit prefix, e.g., No. 11-0001 was the first 20-inch drill press as of October 1956.
15-inch Drill Press
Type 1:
9D140 | 1-1140 |
9D1040 | 1-944 |
9D943 | 1-147 |
Type 2:
20-inch Drill Press
Type 1:
D11241 | 2-1143 |
D11242 | 2-644 |
D11542 | 27-1144 (PF) |
D11642 (PF) | 27-546 (PF) |
D1143 | 2-546 |
Type 2:
Bandsaws¶
Tablesaws
Radial Drills
Jig Saws (Scroll Saws)
Lathes
Sanders¶
Jointers
Shapers
Radial arm saws
Cut-off Machines
