Page Revision: 2009/01/17 22:51
Table of Contents [Hide/Show]
      15-inch Drill Press
         Type 1:
         Type 2:
      20-inch Drill Press
         Type 1:
         Type 2:
      Bandsaws
         Type 1:
         Type 2:
      Tablesaws
         Type 1:
         Type 2:
      Radial Drills
         Type 1:
         Type 4:
      Jig Saws (Scroll Saws)
         Type 1:
         Type 4:
      Lathes
         Type 1:
         Type 2:
         Type 4:
      Sanders
         Type 1:
         Type 2:
      Jointers
         Type 1:
         Type 2:
      Shapers
         Type 1:
         Type 2:
      Radial arm saws
         Type 1:
         Type 2:
      Cut-off Machines
         Type 1:
         Type 2:
  • 0. No serial numbers. Early machines did not have any serial numbers.
  • 1. The first serial number system began in 1939. These followed no logical pattern and were more akin to a model number than a unit-specific designation. See the machine-specific section below for details.
  • 2. Starting in April of 1950 a new system was introduced. These new serials are formatted YYMSQD where YY is the year of manufacture, M is the type of machine, S is the specific model of machine, Q is the quarter of the year of manufacture, and D notes deviation from the standard model. For example, 52DA2A is a standard (52DA2A) single-spindle (52DA2A) 15" drill press (52DA2A) that was built in the 2nd quarter (52DA2A) of 1952 (52DA2A). Below is a list of the machine type code letters and what they stand for.
BBand SawJJig Saw
CSanderLLathes
SSpindle Shaper
  • 3. The next serial number system was introduced in April 1953 and used until September 1956. Each machine was numbered 0000001, 0000002, etc. The type and model cannot be identified by the number alone. Machine tags used during this time included fields for both Model No. and Serial No. Almost all of the models sold during this time were introduced in 1953.
  • 4. The last serial number system began in October of 1956. The machine type is designated by a two-digit prefix, e.g., No. 11-0001 was the first 20-inch drill press as of October 1956. This system continued until Delta/Rockwell's serial number system replaced it. Walker-Turner machines with a Rockwell serial number badge should be dated according to the Delta Serial Numbers page. Most Rockwell built Walker-Turner machines came from either their Bellefountaine or Tupelo plants.
15-inch Drill Press
Type 1:
9D1401-1140
9D10401-944
9D9431-147
Type 2:
20-inch Drill Press
Type 1:
D112412-1143
D112422-644
D1154227-1144 (PF)
D11642 (PF)27-546 (PF)
D11432-546
Type 2:
Bandsaws
Type 1:
BW740, 1950: 29-449
BN905 14” Wood, 1939 to 1950:
OBS639019-639
19-1049
9BS639020-842
MBS639020-1049
MBS842
110563901105842
1105103921-842
11054421105-448
1135103922-639
113563901135-448
Type 2:
Tablesaws
Type 1:
26-184726-248
26-14826-748
11CS241B16-1147
16-24116-1148
16-54416-548
16-54616-749
Type 2:
“D” indicates TA1182
Radial Drills
Type 1:
RD1170* Radial Drill Press:
RD1410RD1141BRD642S6-642
RD642RD642L5-6426-645
3-6424-6425-645RD-242L
3-6454-645RD-642LSRD-2426L
  • RD1170- Radials differ from RD1175J only in manner of mounting motor.
RD1175J* Radial Drill Press:
RD242B7-6248RD642JS10-642
RD11242BRD642JL9-64210-645
RD642B8-6429-64510-6248
7-6428-6459-6248
7-6458-6248RD-642JLS
  • RD1175J- Radials are the same as present models with the exception of Head Casting and Jackshaft Housing. Other parts are interchangeable.
Type 4:
The early models of 1600 and 1700 Radials were RD1175J units with new name plates. These models only had one digit after the four digit unit number (1616-1 or 1711-2 etc.). These models carried serial numbers as follows: 16-0001 thru 16-0099 17-0001 thru 17-0099
Later models have two digits following the main number (1616-12 or 1711-13 etc.). These models carry serial numbers as follows: 16-0100 and higher 17-0100 and higher
Type 1:
MJ744, dates unknown: 7JS1239
J782, dates unknown: 7JS240
J915*, 1947 to 1959: 25-1147
  • J915 – and model 4510 are identical with the exception of the 45A62 Hold Down and Guide Assy. The new assembly is interchangeable in its entirety.
Type 4:
Lathes
Type 1:
SVL52, 1944: 14-144
L752, 1939: 9L8390
L905, 1939: 7L6390
L1152, dates unknown:
115284114-841
11L34114-947
112841
Type 2:
Type 4:
Sanders
Type 1:
Type 2:
Jointers
Type 1:
Type 2:
Shapers
Type 1:
Type 2:
Radial arm saws
Type 1:
Type 2:
Cut-off Machines
Type 1:
Type 2:
