Page Revision: 2009/01/25 01:37
- 1. The first serial number system began in 1939. These followed no logical pattern and were more akin to a model number than a unit-specific designation. See the machine-specific section below for details. Note that although the original document lists serial numbers with dashes, the numbers that were stamped onto the badges often used a space instead.
A | Tilting Arbor & Table Saw | | G | Grinder |
B | Band Saw | | J | Jig Saw |
C | Sander | | L | Lathes |
D | 15” Drill Press | | P | Planer (Jointer) |
E | 20” Drill Press | | R | Radial Saw & Drill |
| | | S | Spindle Shaper |
- 4. The last serial number system began in October of 1956. The machine type is designated by a two-digit prefix, e.g., No. 11-0001 was the first 20-inch drill press as of October 1956. This system continued until Delta/Rockwell's serial number system replaced it. Walker-Turner machines with a Rockwell serial number badge should be dated according to the Delta Serial Numbers page. Most Rockwell built Walker-Turner machines came from either their Bellefountaine or Tupelo plants.
15-inch Drill Press
Type 1:
900 Series, 1940 through 1947:The following Type 1 serial numbers were listed in the original Rockwell document:
9D140, 9D1040, 9D943, 1-1140, 1-944, and 1-147
While two examples of serial number 9D
P1040 have been entered into the Photo Index, none have been entered for 9D140, 9D1040, 9D943.
Type 1 examples from the owwm.com Photo Index:
9DP1040,
1 1140,
1 944,
1 147Type 2:
50DH2E,
51DM1A,
51DJ3A,
Type 3:
Model 1216-26
0000224
Model 1216-42
0000807,
000102820-inch Drill Press
Type 1:
1100 Series, 1941 through 1952:The following Type 1 serial numbers were listed in the original Rockwell document:
D11241, D11242, D11542, D11642 (PF), D1143, 2-1143, 2-644, 27-1144 (PF), 27-546 (PF), 2-546
Type 2:
Bandsaws¶
Type 1:
19-639, 19-1049
MBN935 14” Metal, 1939 to 1950: 9BS6390, 20-842,
MBS6390, 20-1049, MBS842
MBN1105 16” Metal, 1939 to 1948 (Discontinued 1948): 11056390,
1105842, 11051039,
21-842, 1105442, 1105-448
11356390,
22-639, 1135-448
MCB1150 16” Wood, 1950: 32-1049,
50BD2AMCB1151 16” Wood, 1950: 50BE2A
Type 2:
“A” indicates BW740 | | “D” indicates MCB1150 |
“B” indicates BN905 | | “E” indicates MCB1151 |
“C” indicates BN905 | | “F” indicates MCB1160 |
BW740: 51BA4A
BN905: 51BC3AType 3:
3220: 0000571Type 4:
3200 Series: 32-0036Tablesaws
Type 1:
26-1847 | 26-248 |
26-148 | 26-748 |
11CS241B | 16-1147 |
16-241 | 16-1148 |
16-544 | 16-548 |
16-546 | 16-749 |
Type 2:
“A” indicates TC995 (2100) | | “E” indicates CB970 |
“B” indicates TC996 (2100) | | “F” indicates LC1301 (12” 2300 Series) |
“C” indicates TA1181 | | “G” indicates LC1302 (12” 2300 Series) |
“D” indicates TA1182 |
Radial Drills
Type 1:
RD1170* Radial Drill Press:
RD1410 | RD1141B | RD642S | 6-642 |
RD642 | RD642L | 5-642 | 6-645 |
3-642 | 4-642 | 5-645 | RD-242L |
3-645 | 4-645 | RD-642LS | RD-2426L |
- RD1170- Radials differ from RD1175J only in manner of mounting motor.
RD1175J* Radial Drill Press:
RD242B | 7-6248 | RD642JS | 10-642 |
RD11242B | RD642JL | 9-642 | 10-645 |
RD642B | 8-642 | 9-645 | 10-6248 |
7-642 | 8-645 | 9-6248 |
7-645 | 8-6248 | RD-642JLS |
- RD1175J- Radials are the same as present models with the exception of Head Casting and Jackshaft Housing. Other parts are interchangeable.
Type 4:
16-0001 thru 16-0099
17-0001 thru 17-0099
16-0100 and higher
17-0100 and higher
Jig Saws (Scroll Saws)
Type 1:
MJ744, dates unknown: 7JS1239
J782, dates unknown: 7JS240
J915*, 1947 to 1959: 25-1147
- J915 – and model 4510 are identical with the exception of the 45A62 Hold Down and Guide Assy. The new assembly is interchangeable in its entirety.
Type 4:
Lathes
Type 1:
SVL52, 1944: 14-144
L752, 1939: 9L8390
L905, 1939: 7L6390
L1152, dates unknown:
1152841 | 14-841 |
11L341 | 14-947 |
112841 |
Type 2:
“A” indicates L-1152 | “C” indicates SVL52 |
“B” indicates L-951 | “D” indicates 953 |
Type 4:
Sanders¶
Type 1:
SM700-705, 1939 to 1960:
7SN6390 | 13-6390 |
7SN1139 | 13-1139 |
Type 4:
Jointers
Type 1:
P908, 1940: 8J240 & 12J240
Type 2:
Type 3:
Type 4:
Shapers
Type 1:
S1140, 1949 to 1953: 14-149
S1141, 1949 to 1953: 14-3249
Type 2:
Type 4:
Radial arm saws
Type 1:
27-449 | 28-449 |
27-1149 | 28-1149 |
27-549 | 33-1149 |
| 34-1149 |
RA9390 | RA143WR |
RA510 | RA343HB |
RA5410 | 23-243 |
RA540 | RA343 |
RA640 | RA642 |
RA642 | 3-1949 |
11RA343 |
Type 2:
- Some 4200 series units were produced with an A. O. Smith direct drive motor. These proved highly unsatisfactory and were discontinued immediately. Some difficulties will arise on radial saw parts orders due to our lack of Parts Manuals and a lack of any manufacturing records. All orders for gearhead motor parts MUST include the “GB” number of the motor. This is our only positive identification of the motors since H.P etc....or manufacturer's serial numbers do not mean anything. Any questions on these machines should be referred to Headquarters Office. (Note: The preceding was kept intact purely due to the fascinating insight it provides into the service of these machines).
Cut-off Machines
Type 4:
