Page Revision: 2009/01/17 21:18
- 1. The first serial number system began in 1939. These followed no logical pattern and were more akin to a model number than a unit-specific designation. See the machine-specific section below for details.
A | Tilting Arbor & Table Saw | | G | Grinder |
B | Band Saw | | J | Jig Saw |
C | Sander | | L | Lathes |
D | 15” Drill Press | | P | Planer (Jointer) |
E | 20” Drill Press | | R | Radial Saw & Drill |
| | | S | Spindle Shaper |
- 3. The next serial number system was introduced in April 1953 and used until September 1956. Each machine was numbered 0000001, 0000002, etc. The type and model cannot be identified by the number alone. Almost all of the models sold during this time were introduced in 1953.
- 4. The last serial number system began in October of 1956. The machine type is designated by a two-digit prefix, e.g., No. 11-0001 was the first 20-inch drill press as of October 1956.
15-inch Drill Press
Type 1:
9D140 | 1-1140 |
9D1040 | 1-944 |
9D943 | 1-147 |
Type 2:
20-inch Drill Press
Bandsaws¶
Tablesaws
Radial Drills
Jig Saws (Scroll Saws)
Lathes
Sanders¶
Jointers
Shapers
Radial arm saws
Cut-off Machines
