Page Revision: 2009/01/17 21:33
Table of Contents [Hide/Show]
      15-inch Drill Press
         Type 1:
         Type 2:
      20-inch Drill Press
         Type 1:
         Type 2:
      Bandsaws
      Tablesaws
      Radial Drills
      Jig Saws (Scroll Saws)
      Lathes
      Sanders
      Jointers
      Shapers
      Radial arm saws
      Cut-off Machines
  • 0. No serial numbers. Early machines did not have any serial numbers.
  • 1. The first serial number system began in 1939. These followed no logical pattern and were more akin to a model number than a unit-specific designation. See the machine-specific section below for details.
  • 2. Starting in April of 1950 a new system was introduced. These new serials are formatted YYMSQD where YY is the year of manufacture, M is the type of machine, S is the specific model of machine, Q is the quarter of the year of manufacture, and D notes deviation from the standard model. For example, 52DA2A is a standard (52DA2A) single-spindle (52DA2A) 15" drill press (52DA2A) that was built in the 2nd quarter (52DA2A) of 1952 (52DA2A). Below is a list of the machine type code letters and what they stand for.
BBand SawJJig Saw
CSanderLLathes
SSpindle Shaper
  • 3. The next serial number system was introduced in April 1953 and used until September 1956. Each machine was numbered 0000001, 0000002, etc. The type and model cannot be identified by the number alone. Machine tags used during this time included fields for both Model No. and Serial No. Almost all of the models sold during this time were introduced in 1953.
  • 4. The last serial number system began in October of 1956. The machine type is designated by a two-digit prefix, e.g., No. 11-0001 was the first 20-inch drill press as of October 1956.
15-inch Drill Press
Type 1:
9D1401-1140
9D10401-944
9D9431-147
Type 2:
20-inch Drill Press
Type 1:
D112412-1143
D112422-644
D1154227-1144 (PF)
D11642 (PF)27-546 (PF)
D11432-546
Type 2:
Bandsaws
Tablesaws
Radial Drills
Lathes
Sanders
Jointers
Shapers
Radial arm saws
Cut-off Machines
