Page Revision: 2009/01/18 18:00
Table of Contents [Hide/Show]
      15-inch Drill Press
         Type 1:
         Type 2:
         Type 3:
      20-inch Drill Press
         Type 1:
         Type 2:
      Bandsaws
         Type 1:
         Type 2:
      Tablesaws
         Type 1:
         Type 2:
      Radial Drills
         Type 1:
         Type 4:
      Jig Saws (Scroll Saws)
         Type 1:
         Type 4:
      Lathes
         Type 1:
         Type 2:
         Type 4:
      Sanders
         Type 1:
         Type 4:
      Jointers
         Type 1:
         Type 2:
         Type 3:
         Type 4:
      Shapers
         Type 1:
         Type 2:
         Type 4:
      Radial arm saws
         Type 1:
         Type 2:
      Cut-off Machines
         Type 4:
  • 0. No serial numbers. Early machines did not have any serial numbers.
  • 1. The first serial number system began in 1939. These followed no logical pattern and were more akin to a model number than a unit-specific designation. See the machine-specific section below for details.
  • 2. Starting in April of 1950 a new system was introduced. These new serials are formatted YYMSQD where YY is the year of manufacture, M is the type of machine, S is the specific model of machine, Q is the quarter of the year of manufacture, and D notes deviation from the standard model. For example, 52DA2A is a standard (52DA2A) single-spindle (52DA2A) 15" drill press (52DA2A) that was built in the 2nd quarter (52DA2A) of 1952 (52DA2A). Below is a list of the machine type code letters and what they stand for.
BBand SawJJig Saw
CSanderLLathes
SSpindle Shaper
  • 3. The next serial number system was introduced in April 1953 and used until September 1956. Each machine was numbered 0000001, 0000002, etc. The type and model cannot be identified by the number alone. Machine tags used during this time included fields for both Model No. and Serial No. Almost all of the models sold during this time were introduced in 1953.
  • 4. The last serial number system began in October of 1956. The machine type is designated by a two-digit prefix, e.g., No. 11-0001 was the first 20-inch drill press as of October 1956. This system continued until Delta/Rockwell's serial number system replaced it. Walker-Turner machines with a Rockwell serial number badge should be dated according to the Delta Serial Numbers page. Most Rockwell built Walker-Turner machines came from either their Bellefountaine or Tupelo plants.
15-inch Drill Press
Type 1:
The following Type 1 serial numbers were listed in the original Rockwell document:
9D140, 9D1040, 9D943, 1-1140, 1-944, and 1-147
While two examples of serial number 9DP1040 have been entered into the Photo Index, none have been entered for 9D140, 9D1040, 9D943.
Type 1 examples from the owwm.com Photo Index:
9DP1040, 1 1140, 1 944, 1 147
Note that although the original document lists serial numbers with dashes, the numbers that were stamped onto the badges used a space instead.
Type 2:
900 Series
1200 Series
1300 Series
Type 3:
1200 Series
Model 1216-26 0000224
20-inch Drill Press
Type 1:
D112412-1143
D112422-644
D1154227-1144 (PF)
D11642 (PF)27-546 (PF)
D11432-546
Type 2:
Bandsaws
Type 1:
BW740, 1950: 29-449
BN905 14” Wood, 1939 to 1950:
OBS639019-639
19-1049
9BS639020-842
MBS639020-1049
MBS842
110563901105842
1105103921-842
11054421105-448
1135103922-639
113563901135-448
Type 2:
Tablesaws
Type 1:
26-184726-248
26-14826-748
11CS241B16-1147
16-24116-1148
16-54416-548
16-54616-749
Type 2:
“D” indicates TA1182
Radial Drills
Type 1:
RD1170* Radial Drill Press:
RD1410RD1141BRD642S6-642
RD642RD642L5-6426-645
3-6424-6425-645RD-242L
3-6454-645RD-642LSRD-2426L
  • RD1170- Radials differ from RD1175J only in manner of mounting motor.
RD1175J* Radial Drill Press:
RD242B7-6248RD642JS10-642
RD11242BRD642JL9-64210-645
RD642B8-6429-64510-6248
7-6428-6459-6248
7-6458-6248RD-642JLS
  • RD1175J- Radials are the same as present models with the exception of Head Casting and Jackshaft Housing. Other parts are interchangeable.
Type 4:
The early models of 1600 and 1700 Radials were RD1175J units with new name plates. These models only had one digit after the four digit unit number (1616-1 or 1711-2 etc.). These models carried serial numbers as follows: 16-0001 thru 16-0099 17-0001 thru 17-0099
Later models have two digits following the main number (1616-12 or 1711-13 etc.). These models carry serial numbers as follows: 16-0100 and higher 17-0100 and higher
Type 1:
MJ744, dates unknown: 7JS1239
J782, dates unknown: 7JS240
J915*, 1947 to 1959: 25-1147
  • J915 – and model 4510 are identical with the exception of the 45A62 Hold Down and Guide Assy. The new assembly is interchangeable in its entirety.
Type 4:
Lathes
Type 1:
SVL52, 1944: 14-144
L752, 1939: 9L8390
L905, 1939: 7L6390
L1152, dates unknown:
115284114-841
11L34114-947
112841
Type 2:
Type 4:
Sanders
Type 1:
SM700-705, 1939 to 1960:
7SN639013-6390
7SN113913-1139
Type 4:
Jointers
Type 1:
P908, 1940: 8J240 & 12J240
Type 2:
Type 3:
Type 4:
Shapers
Type 1:
S1140, 1949 to 1953: 14-149
S1141, 1949 to 1953: 14-3249
Type 2:
Type 4:
Radial arm saws
Type 1:
27-44928-449
27-114928-1149
27-54933-1149
34-1149
RA9390RA143WR
RA510RA343HB
RA541023-243
RA540RA343
RA640RA642
RA6423-1949
11RA343
Type 2:
  • Some 4200 series units were produced with an A. O. Smith direct drive motor. These proved highly unsatisfactory and were discontinued immediately. Some difficulties will arise on radial saw parts orders due to our lack of Parts Manuals and a lack of any manufacturing records. All orders for gearhead motor parts MUST include the “GB” number of the motor. This is our only positive identification of the motors since H.P etc....or manufacturer's serial numbers do not mean anything. Any questions on these machines should be referred to Headquarters Office. (Note: The preceding was kept intact purely due to the fascinating insight it provides into the service of these machines).
Cut-off Machines
Type 4:
