Page History: Yearly Maintenance Checklist
Page Revision: 2009/01/03 12:41
From owwm.com forum thread http://owwm.org/viewtopic.php?t=48970 by Bob Vaughan
You can use this downloadable version to use as a template for your own shop. Print it out and check off the items as you do them.
Kit (tool box top tray works well)
_
Oilcan
_
Grease
_
Cleaning rags
_
Allen wrenches
_
Cover removal tools (screwdrivers & wrenches)
_
Note pad and pencil (for noting big things & checking off items)
_
Small flashlight
_
Inspection mirror
_
Clipboard with this list attached
Table saw
_
Blow out
_
Oil trunnions & gears
_
Tighten setscrews on handwheels
_
Check for loose pulley setscrews & belt wear
_
Inspect plug, cord, & starter
Radial Arm Saw
_
Clean tracks & oil
_
Bandsaw
_
_
Blow out
_
Check guides for wear
_
Oil upper wheel carriage
_
Scroll saw
_
_
Blow out
_
Check oil level
_
Drop of oil in upper plunger
_
Bench grinders
_
Blow out
_
Check wheels
_
_
_
Clean Morse taper sockets
_
Clean and oil tailstock clamp mechanism
_
_
_
Clean and oil working parts on fence
_
Inspect knives
_
_
_
Check belts
_
Grease fittings, oil moving parts
_
Check knives
_
_
_
Clean and oil working parts.
_
Drill press
_
_
_
Check chuck jaws
_
Mortiser
_
_
Oil working parts
Tenoner
_
_
Clean track
_
Oil working parts
Sander
_
_
_
Check oil level on OSS
_
Oil moving parts
Compressor
_
_
Check oil
_
Drain tank
_
Power Feeder
_
Check oil level
_
Inspect wheels, gears and chain
_
_
Oil working parts
Portable Power Tools
_
Gearbox oil (where needed)
_
Cords
___
Brushes
