Crescent 36" Band Saw Restoration
Modified on 2010/07/31 14:38 by krucker — Categorized as: Bandsaws, Restoration Topics
by Keith S. Rucker
Now that you have read all of the above and have a good background on how to get started, lets go over how to actually do it. The main thing to remember about pouring babbitt is that it is not rocket science. The first time that I ever did it, I did not have the advantage of being able to read all about it here. This write up is actually about my first try and as you will see, I was ultimately successful!
With little to do on the saw until the castings of the broken parts get back from the foundry, I decided what the heck, the bearings needed to be poured on the bottom shell of the bottom bearing - might as well go ahead and get that part out of the way. So, for those that have never poured Babbitt bearings before, here is how I do it.
1.1 - Clean the parts
 The bearing shell before cleaning
 The bearing shell after cleaning
1.2 - Setting up to pour
 The bottom shell and arbor set up and ready for a pour
1.3 - Melting the Babbitt
 The ingot of babbitt metal melting on the camp stove
1.4 - Heat the parts
 Using a propane torch to pre-heat the bearing shell and arbor
 Skimming the babbitt and checking the temperature with a pine stick
 The two bearings after the pour
1.7 - After the pour
 The bearings after removing the arbor
 Looking good!
Looking good!
2 - Tuesday, Nov. 11, 2004
The new castings from Cattail Foundry (see: Foundry Sources) came in the week of Thanksgiving. Total time from when I sent the repaired castings off to be used as patterns to when the new castings came back to me was about six weeks. Not too bad I guess. Total price for re-casting the four parts was $114 including shipping. Now that is not bad at all! If I had been able to find new old stock parts, I know it would have cost me more than that.
 The new castings next to the repaired parts used as patterns as received from Cattail foundry
3 - Monday, Nov. 29, 2004
I next went to a farm shop of a local farmer that I know very well to use his milling machine. The farmer knows that I use to work as a machinist and has always invited me to use his shop whenever I needed to - as long as I help him out every now and then when they need something done in his shop that his workers cannot do (he does not have a trained machinist working there). On the mill, I drilled out all of the bolt holes so they would line up. On the top wheel bearing, the bottom half of the casting is tapped to receive the bolts from the top bearing. Nothing too challenging but using the mill rather than a drill press made it go much easier.
4 - Friday, Dec. 3, 2004
4.1 - Setting up for the pour
I actually began by working on the top bearing assembly. First, I laid everything out just like I did with the bottom wheel bearing assembly and poured it using the same technique.
4.2 - The pour
