DeWalt MBF & MBC Motor Bearing Replacement
Modified on 2008/04/06 12:04 by joewells — Categorized as: Bearings, Restoration Topics
Alright
Ok
Getting Better
Pretty Good
Awesome
A Japanese JAF 88500 was used to replace the Fafnir 200KLL2 on the cord side and a Japanese IKS 88504 to replace the New Departure C 88504 on the arbor side. These bearings were ordered from
Accurate Bearing
and are fairly standard.
From owwm.org thread:
http://owwm.org/viewtopic.php?t=30990
