Delta 6x48 Sander Tables, Fences and Stops
Modified on 2018/04/21 18:01 by bullmastiff — Categorized as: Restoration Topics, Sanders
Tables
Comparison
The photo below from Bob Vaughan compares a table and trunnion from a late model disc/belt sander (left) with the older style (right). Note the repaired break on the late model trunnion, a known point of failure.Worn drum on 6x48 sander
Pics! Delta 6" Belt 12"DiskSander #31-730 for $100
Delta Belt/Disk Sander 31-730F
Table Lip Repair
By Shane Whitlock
Rockwell Belt Sander Restoration Pics (updated all finished).
Stops
Marc D provided the following reference images for anyone wanting to fabricate their own stop
Delta 6X48 "backstop" 31-403:
The banjo/bracket is 5 1/2" long, 1 inch high and 1 inch wide. The slot is just less than 1/2"
WTB: Backstop Delta 6x48 sander....
