Delta Cast Iron Stand Study
Modified on 2018/09/16 22:07 by Jeff Joslin — Categorized as: Manufacturer Information
(from a post on OWWM.org by by Keith Bohn 09/24/06) http://www.owwm.org/viewtopic.php?t=20014
Delta No. 667 Cast Iron Stand
Delta No. 886 Cast Iron Stand
No. 31-852 Cast Iron Stand
No. 886 Stand for Tablesaw
No. 37-302 Cast Iron Stand
No. 37-302 Jointer Stand
No. 31-852 & No. 886 Comparison Photos
No. 31-852 on left, No. 886 on right - image courtesy of Jeff Parker (JParker)
No. 31-852 on left, No. 886 on right - Image courtesy of Jeff Parker (JParker)
