K-Line K2200 planer
Modified on 2010/06/28 14:55 by BobHolcombe — Categorized as: Uncategorized
K-Line model K2100
planer. Richard Kneisley's design for the earlier model is an elegant and wonderfully engineered machine. It has a power “automatic table adjustment device”. By engaging the clutch the single adjusting screw raises or lowers the table. Final adjusting is done by hand adjusting the 14” center wheel.
The 1949 K2100 guide plate.
Another inside view with sheet metal covers removed.
Pinion bracket shown on top of casting.
picChipbreaker
Chipbreaker
Inside cabinet showing motor pulley arrangement
