Replacement Bearing List - Sears Craftsman/Companion/Dunlap/Fulton/Kenmore Machinery
Modified on 2022/06/22 16:05 by Bill Widmer — Categorized as: Bearings, Restoration Topics
Table of Contents [Hide/Show]
      Craftsman (12") 103.24250
      Craftsman (12") 103.24280
      Craftsman (12") 113.24330
      Craftsman 103.0303
      Craftsman 103.23100
      Craftsman 103.23130
      Craftsman 103.2482x
      Craftsman (6") Cat# 2601
      Craftsman (6") 113.6605
      Craftsman (8") 109.66120
      Craftsman (6") 103.6614
      Craftsman (6") xxx.6649
Grinder - 6" Electric
      Companion 115.5273
      Craftsman 115.7561
      Craftsman 397.19391
      Craftsman 115.19500
      Craftsman 397.19589
Grinder - 7" Electric
      Craftsman 5120 (Cat# 2609)
      Craftsman 115.6965
      Craftsman 115.7575
      Craftsman 397.1949
Grinder - 8" Electric
      Craftsman 397.19670
      Craftsman 257.192190
      Craftsman (4¼") 103.0502
      Craftsman (6") 102.05600
ROUTER
SANDER
      Dunlap 534.09760
      Craftsman 113.239420
Craftsman 103.0303
Craftsman 103.23100
Craftsman 103.23130
Craftsman 103.2482x
Companion 115.5273
Craftsman 115.7561
Craftsman 397.19391
Craftsman 115.19500
Craftsman 397.19589
Craftsman 115.6965
Craftsman 115.7575
Craftsman 397.1949
Craftsman 397.19670
ROUTER
SANDER
Dunlap 534.09760
