Unisaw Type Study
Modified on 2019/02/25 10:14 by antioxidant — Categorized as: Manufacturer Information
1 - Site of manufacture
2 - User’s Manual
3 - Casting Marks & Parts Prefixes
4 - Tops and Extensions
5 - Fence
6 - Fence Locking Lever Knob
7 - Fence Micro-Adjustment Knob
8 - Rear Fence Rail Locking Thumb Nut
9 - Fence Rails
10 - Miter Gauge
The holes for an auxiliary fence are threaded for #12-24
1939: Catalog artwork shows the No. 864 Auto-Set Miter Gauge with two squared shoulders. This was the standard miter gauge at the time. Early miter gauges had decals and patent numbers cast into the head.
1940: An illustration in “Instructions for Operating Circular Saw Guards” dated 3/40 shows the No. 864 miter gauge with the left hand shoulder slightly clipped. It was noted that this was done to clear the blade guard.
1942: Catalog artwork for the No. 20-200 8-Inch Tilting Table Saw shows the No. 864 miter gauge with the two shoulders clipped at 45 degrees. It is assumed that this same gauge would have been sold with the Unisaw. Also by this time Delta was using the Delta/Milwaukee brand name and it is assumed that this would also have been cast into the head of the miter gauges of that vintage.
11 - Blade Guards
12 - Cabinet
19XX the dust door opening changed to have two 6" long tabs on the sides (one each side) and two tabs on the top 2" long. These tabs are for the dust door to rest against. A late 1947 saw exhibits these tabs, so this change must have been made sometime prior to that date.
13 - Cabinet Bottom
14 - Dust Door
15 - Tilt Scale
16 - Switches & Switch Plates
17 - Motor Cover
1939: The cast iron goose egg motor cover (LTA-474) was made available as an accessory (Cat. No. 1454). It weighs 23 pounds and held in place by four #12-24 x 1/2" Indented Hex Head Self-Drilling screws. Photo credit goes to User:Torquester: http://vintagemachinery.org/classifieds/images/14616-3-z.jpg.
UPDATE 2019: The screws were originally documented here as 1/4-20 x 1/2" (in 2008), but User:antioxidant found #12-24 x 3/4" to be a perfect fit on his machine. 1/2" length was simply too short. The #12-24 thread matches the miter gauge's threads as well.
18 - Handwheels
19 - Handwheel Tightening Knobs
20 - Serial Number Plate
21 - Base (Feet or Plinth
22 - Motors
Three-Phase Motors:
Direct Current Motors:
23 - Drive Train
