Avey Drilling Machine Co.
RSS
Modified on 2018/08/27 21:20 by Joel Havens Categorized as Manufacturer Information
Two record numbers are shown on every Avey Drill when it leaves the factory.
Machine Serial Numbers shipped before 1928 were stamped on the countershaft loose pulley cap on Belted Avey Drills. After 1928, this machine serial number was stamped on a brass name plate attached to each machine.
Base numbers will be found stamped into the top of the lower column dovetail, which carries the table.
Serial No.Base NumberTypeMachine DescriptionDate
R90318215Drilling MachinesAll Drills Dec 1920
R92338350Drilling MachinesAll Drills Dec 1921
R96758651Drilling MachinesAll Drills Dec 1922
R103479131Drilling MachinesAll Drills Dec 1923
R108809681Drilling MachinesAll Drills Dec 1924
R1164210443Drilling MachinesAll Drills Dec 1925
R1164211259Drilling MachinesAll Drills Dec 1926
R1337412075Drilling MachinesAll Drills Dec 1927
1427912815Drilling MachinesAll Drills Dec 1928
1540513700Drilling MachinesAll Drills Dec 1929
1586914120Drilling MachinesAll Drills Dec 1930
1598514191Drilling MachinesAll Drills Dec 1931
1600714225Drilling MachinesAll Drills Dec 1932
1603414240Drilling MachinesAll Drills Dec 1933
16167114322Drilling MachinesAll Drills Dec 1934
1642814544Drilling MachinesAll Drills Dec 1935
1679714896Drilling MachinesAll Drills Dec 1936
1734915342Drilling MachinesAll Drills Dec 1937
17547115539Drilling MachinesAll Drills Dec 1938
1778315765Drilling MachinesAll Drills Dec 1939
1871616384Drilling MachinesAll Drills Dec 1940
1994417519Drilling MachinesAll Drills Dec 1941
2161018919Drilling MachinesAll Drills Dec 1942
2283020124Drilling MachinesAll Drills Dec 1943
23407120644Drilling MachinesAll Drills Dec 1944
2398321141Drilling MachinesAll Drills Dec 1945
2446121538Drilling MachinesAll Drills Dec 1946
2473021736Drilling MachinesAll Drills Dec 1947
2499921961Drilling MachinesAll Drills Dec 1948
2519722127Drilling MachinesAll Drills Dec 1949
2548622375Drilling MachinesAll Drills Dec 1950
2612322934Drilling MachinesAll Drills Dec 1951
2684723601Drilling MachinesAll Drills Dec 1952
3071430714Drilling MachinesAll Drills Dec 1953
3136731367Drilling MachinesAll Drills Dec 1954
3183231832Drilling MachinesAll Drills Dec 1955
3226832268Drilling MachinesAll Drills Dec 1956
3255332553Drilling MachinesAll Drills Dec 1957
  • Serial Number Reference Book for Metalworking Machinery, by the Industrial Publishing Corp., 1959
