Decals - Craftsman
RSS
Modified on 2017/04/12 09:46 by Jeff Joslin Categorized as Decals
Craftsman / Blue Badge
submitted by Treetrimmer 6 (Right click and select "save target as" to download High-res version)
 Craftsman Power Tools Badge (late 30's-early 40's). Submitted by Maury Hurt (maurywhurt)
(Left click on thumbnail to see high-res version of restored badge image, then right right click and select "save image as" to download. This is badge is from a 1938 Craftsman Band Saw, model 102.01121.)
Craftsman Decal 1935-1944. Submitted by Maury Hurt (maurywhurt)
(Left click on thumbnail image to see high-res version of restored decal, then right right click and select "save image as" to download. The original decals were printed in several lengths, including 2-5/8" and 3-3/8")
Craftsman Bearing. Submitted by cbdeajr
((Right click and select, in IE:'Save Target As...', in Firefox:'Save Link As...', to download High-res version)
This one comes from a Craftsman bench top DP (101.03580) manufactured by Atlas Press. I wouldn't be surprised if this decal appears on other machines. Submitted by NeilB
This is a restored image of an original SKF Bearing decal from a Craftsman floor model drill press (101.03622) manufactured by Atlas Press. Submitted by Maury Hurt (maurywhurt)
(Left click on thumbnail image to see high-res version of restored decal, then right right click and select "save image as" to download. Width of original decal is 2".)
This is a restored image of an original SKF Bearing decal from a Craftsman band saw (102.01121) manufactured by Walker-Turner. Submitted by Maury Hurt (maurywhurt)
This is a remastered image of the restored SKF Bearing decal submitted by Maury Hurt (maurywhurt). This decal will be used on a Craftsman 12 3/4
This is a remastered image of the restored SKF Bearing decal submitted by Maury Hurt (maurywhurt). This decal will be used on a Craftsman 12 3/4" benchtop drill press made by Atlas with the model/year unknown. Remastered/Submitted by Jeff Bird (Licher)
Craftsman / Planer Submitted by NeilB
Craftsman / King-Seeley Submitted by NeilB
Craftsman Highest Quality
Sears, Roebuck and Co. Model Number Badge from a 1930's Machine
submitted by John Beckman (Right click and select, in IE:'Save Target As...', in Firefox:'Save Link As...', to download High-res version)
Craftsman Asbestos Protected
submitted by John Gaasland (gaaslaj)(Right click and select, in IE:'Save Target As...', in Firefox:'Save Link As...', to download High-res version)
Craftsman RAS
Craftsman RAS
submitted by kraymo (Right click and select, in IE:'Save Target As...', in Firefox:'Save Link As...', to download High-res version)
Alien Head Scale
Alien Head Scale
Craftsman Power Panel
Restored image of Craftsman Power Pak decal. Submitted by Maury Hurt (maurywhurt)
(Left click on thumbnail image to see high-res version of restored decal, then right right click and select "save image as" to download. Width of original decal is 3-3/16".)
Restored image of Craftsman 115 series Thermotron-Protected Motor decal (Bottom of decal mounted 3/8
Restored image of Craftsman 115 series Thermotron-Protected Motor decal (Bottom of decal mounted 3/8" above and centered on metal data tag). Submitted by Maury Hurt (maurywhurt)
(Left click on thumbnail image to see high-res version of restored decal, then right right click and select "save image as" to download. Width of original decal is 1-5/16".)
Craftsman 397.19370 bench grinder decal
Created by Steve White (Right click and select, in IE:'Save Target As...', in Firefox:'Save Link As...', to download High-res version)
