Welcome
Guest
Wiki Home
VintageMachinery.org Home
OWWM.org Home
Donate
Search the Wiki:
Main Page
Random Page
Create a new Page
All Pages
Categories
File Management
Create Account
Help Topics
Discuss (0)
View Page Code
History
PM 1150A VS spindle and bearing replacement
Print
RSS
Modified on 2009/02/03 19:45
by
wan2fly
Categorized as
Drill Presses
Maintenance
(10)
Origins of Two Bladed Table Saws
Our Mission
[X]
OLIVER EARLY SERIAL NUMBERS
Oliver Machinery Co. Serial Numbers
OWWM.org vs Vintagemachinery.org
Oliver Machinery Co. Catalog Study
Oliver shaper spindle removal
Early History of The Oliver Machinery Company
A Brief history of the Oliver Machinery Company
Our Mission
by wan2fly / Tom Haney
I picked up this Powermatic 1150A Variable Speed Drill press despite it having 0.01" of runout at the tip of the JT33 taper spindle. This runout translated to a very large amount once chuck was installed and a drill bit inserted. Pretty much unusable.
Suggestions were made by skilled and knowledgeable people about using a bottle jack to nudge the taper true. I was not successful at this and did not want to risk further harm. I decided to replace the spindle and bearings.
After removing and inspection of the spindle I noticed that the lower spindle bearing had not been driven all the way down to it's seat. I believe that my original spindle may have been perfectly good and the entire problem was improperly seated bearing. It would be a relatively easy thing to verify before one orders new expensive parts like this spindle. I'm just sayin'.
Here is some relevant further reading I suggest, with gratitude to authors and contributors:
Model 1150 15" Drill Press Maintenance Instructions and Parts List
Drill press tune-up article by Bob Vaughan (pdf)
http://www.owwm.org/viewtopic.php?t=41350
http://www.owwm.org/viewtopic.php?t=46088
Here is an image of the 1991 PM 1150A Variable Speed DP during the process of measuring runout. The dial indicator on on the flexible arm is measuring the runout at the tip of the taper of the spindle.
Here are the new parts ready to be installed:
ScrewTurn Wiki
FamFamFam
